Getting Started with M2P
Read more: Banana Pi BPI-M2+
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
Build your own image on M2P
GPIO
- Execute "bluetoothctl"
- If you don't know how to use bluetoothctl, type help, you will see more commands
- Execute these commands:
[[Image:M2P_BT_bluetoothctl.png] [[Image:M2P_BT.png]
WiFi and Ap mode on M2P
AP mode
We use HDF5640 camara.
- test_ov5640_image_mode.sh
- cameratest.sh
IR function
- Execute getevent
WringPi
- Execute bpi_test_lcd1602
- RGB 1602 LCD
- Execute bpi_test_52pi
- 0.96 Inch OLED Display
- 8x8 RGB LED Martix
