Banana Pi Smart Router /Nas Comparison
Module |
Banana Pi BPI-R1 |
Banana Pi BPI-R2 |
Banana Pi BPI-W2
Photo |
CPU |
Allwinner A20,32 Bit Cortex™-A7 2-Core 1G |
MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz |
Realtek RTD1296 64 Bit quad-core ARM A53
GPU |
ARM® Mali400MP2 |
ARM® Mali450 MP4 |
Mali T820 MP3 GPU
SDRAM |
1GB DDR3 (shared with GPU) 432Mhz |
2GB DDR3 (shared with GPU) 1600Mhz |
2GB DDR4 \(shared with GPU\)
Storage |
"SD Card up to 64GB (SDXC) 1 SATA up to 2TB " |
"MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB " |
Network |
4x Gigabit LAN 1x Gigabit WAN |
4x Gigabit LAN 1x Gigabit WAN (MT7530) |
1x Gigabit LAN 1x Gigabit WAN
WIFI |
802.11b/g/n (RTL8192CU) |
"802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)" |
N/A
Vidio In |
CSI input for video cameras |
NA |
HDMI in
Video Out |
HDMI/LVDS/RGB |
HDMI/MIPI |
HDMI/ MIPI DP
Audio Output |
3.5 mm Jack and HDMI out |
HDMI out & I2S |
HDMI out, I2S audio,Audio micro out
Audio In |
Microphone |
N/A |
2 MIC in and HDMI in
USB 2.0 |
2 USB 2.0 ports, 1 OTG microUSB port |
1 USB 2.0 OTG |
2x USB 2.0 OTG :1 with standard USB port , 1 define with PIN
USB 3.0 |
N/A |
2xUSB 3.0 |
1xUSB 3.0
HDMI in |
N/A |
N/A |
1 HDMI in
TYPE C |
N/A |
N/A |
1x TYPE C
Mini DP |
N/A |
N/A |
1x Mini DP
PCIE |
N/A |
1* mini PCIE,1*pcie with 14 PIN define |
1xM.2 KEY B : USB 2.0 for 4G with Micro SIM card slot ;2xM.2 KEY E:1 with PCIE 2.0/USB 2.0,1 with 1 pcie 1.1/SDIO/USB 2.0 interface
GPIO 40-PIN |
GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. |
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
Power Source |
5 volt via MicroUSB and/or MicroUSB (OTG) |
12 volt via DC In |
12 volt via DC In
Buttons |
Reset button Power button, Uboot button |
LED |
Power key and RJ45 |
Power key and RJ45
Remote |
IR reciever |
IR reciever |
IR reciever
Board Size |
120mm ×100mm |
120mm ×100mm |
120mm ×100mm
Weight |
60g |
60g |
60g
OS |
Android and Linux OS OpenWRT |
