Getting Started with BPI-R4
Revision as of 23:04, 21 December 2023 by Sinovoip (talk | contribs) (How to burn image to onboard Nand)
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
How to burn image to SD card
   * apt-get install pv
   1. Download the tools from the website:   https://sourceforge.net/projects/win32diskimager/
   3. flash image into SD card.
 Note: because SD card and EMMC device share one SOC's interface, you need flash one SD image firstly, then R3 boot from SD card, then flash nand image into Nand, then change boot strap to boot from nand,  you need flash EMMC image into EMMC. Finally you change bootstrap to boot from EMMC.
    * mtd erase /dev/mtd0
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
eth2 Link encap:Ethernet HWaddr 22:02:CE:9C:92:BA
         Interrupt:124
lo Link encap:Local Loopback
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:88
ra1 Link encap:Ethernet HWaddr 02:0C:43:36:60:88
rai0 Link encap:Ethernet HWaddr 00:0C:43:2B:B1:F8
rax0 Link encap:Ethernet HWaddr 0C:0C:43:26:60:D8
bridge name bridge id STP enabled interfaces br-wan 7fff.eea15781ca19 no lan0, eth2
bridge name bridge id STP enabled interfaces br-lan 7fff.eea15781ca19 no apclii0 apclix0 apcli0 ra1 rai0 rax0 lan2 eth1 ra0 lan3 lan1
root@OpenWrt:/#
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
  • BPI-R4 supports 4G LTE EC25. Quectel RM500U-CN & RM520N-GL 5G Modules.
  • If you want to use 5G on BPI-R4:
3. SSD
  • please insert one M2.KeyM SSD into M2.KeyM slot.
4. Asia mPCIe WiFi6/WiFi6E
