Getting Started with BPI-R4
Revision as of 05:00, 21 December 2023 by Sinovoip (talk | contribs) (→3. SSD)
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
  • BPI-R4 supports 4G LTE EC25. Quectel RM500U-CN & RM520N-GL 5G Modules.
  • If you want to use 5G on BPI-R4:
3. SSD
  • please insert one M2.KeyM SSD into M2.KeyM slot.
4. Asia mPCIe WiFi6/WiFi6E
