Getting Started with BPI-R4
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
  • BPI-R3 supports 4G LTE EC25.
  • If you want to use 5G on BPI-R3:
3. SSD
4. Asia mPCIe WiFi6/WiFi6E
