Banana Pi BPI-M6
About VideoSmart VS680
- Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
- Imagination GE9920 GPU
- NPU for AI up to 6 .75Tops
- 4GB LPDDR4
- 16GB eMMC flash
- M.2 Key E(PCIe + MIPI CSI)
- 4 USB 3.0
- 1 GbE ethernet
- 1 HDMIin and 1 HDMIout
| HardWare Specification of Banana pi BPI-M6 | |||
| CPU | Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor | ||
| GPU | Imagination GE9920 GPU | ||
| NPU for AI | Up to 6 .75Tops | ||
| Memory | 4 GB LPDDR4 | ||
| Video | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port | ||
| Audio Output(s) | 1 x HDMI digital output | ||
| Display | MIPI DSI interface | ||
| M.2 interface | M.2 Key E(PCIe + MIPI CSI) | ||
| Switches | SPI boot and U-boot | ||
| Power Source | 5 volt @3A TYPE C | ||
| OS | Android and Linux | ||
| BPI-M6 40PIN Header(CON3) | |||
| BPI-M6-CON3 | PIN | PIN | BPI-M6-CON3 |
| PWR_3V3_CTL | 1 | 2 | PWR_5V |
| GPIO46/TW0_SDA | 3 | 4 | PWR_5V |
| GPIO47/TW0_SCL | 5 | 6 | GND |
| GPIO53/PWM1 | 7 | 8 | SM_GPIO15/UART2_TXD |
| GND | 9 | 10 | SM_GPIO14/UART2_RXD |
| GPIO36/PWM3 | 11 | 12 | GPIO20/I2S1_BCLK |
| GPIO37/PWM2 | 13 | 14 | GND |
| EXPANDER_TW3_GPIO1_4 | 15 | 16 | EXPANDER_TW3_GPIO1_0 |
| PWR_3V3_CTL | 17 | 18 | EXPANDER_TW3_GPIO1_1 |
| SM_GPIO13/SPI2_SDO/URT2_RTS/SM_STRAP1 | 19 | 20 | GND |
| SM_GPIO12/SPI2_SDI/URT2_CTS | 21 | 22 | GPIO4/SPDIF |
| SM_GPIO11/SPI2_SCK | 23 | 24 | SM_GPIO17/SPI2_SS0/SM_STRAP2 |
| GND | 25 | 26 | SM_GPIO16/SPI2_SS1/SM_STRAP3 |
| GPIO15/I2S1_DO3 | 27 | 28 | GPIO16/I2S1_DO2 |
| EXPANDER_TW3_GPIO1_7 | 29 | 30 | GND |
| EXPANDER_TW3_GPIO1_6 | 31 | 32 | EXPANDER_TW3_GPIO1_3 |
| EXPANDER_TW3_GPIO1_5 | 33 | 34 | GND |
| GPIO21/I2S1_LRCK | 35 | 36 | EXPANDER_TW3_GPIO1_2 |
| GPIO18/I2S1_MCLK | 37 | 38 | GPIO17/I2S1_DO1 |
| GND | 39 | 40 | GPIO19/I2S1_DO0 |
| BPI-M6 M.2 E-KEY(CN10) | |||
| PIN | PIN | ||
| GND | 1 | 2 | VCC-NGFF |
| NGFF_KEYE_DP | 3 | 4 | VCC-NGFF |
| NGFF_KEYE_DM | 5 | 6 | WiFi-LED |
| GND | 7 | 8 | SM_GPIO10/TW3_SDA |
| MIPI_CSI0_RD0p | 9 | 10 | SM_GPIO9/TW3_SCL |
| MIPI_CSI0_RD0n | 11 | 12 | NI |
| MIPI_CSI0_RD1p | 13 | 14 | BT-LED |
| MIPI_CSI0_RD1n | 5 | 16 | BT-LED |
| MIPI_CSI0_RD2p | 17 | 18 | GND |
| MIPI_CSI0_RD2n | 19 | 20 | SM_GPIO6/UART_WAKE#Puboot |
| MIPI_CSI0_RD3p | 21 | 22 | GPIO43/UART3_RXD |
| MIPI_CSI0_RD3n | 23 | 24 | NOTCH |
| NOTCH | 25 | 26 | |
| 27 | 28 | ||
| 29 | 30 | ||
| 31 | 32 | GPIO42/UART3_TXD | |
| GND | 33 | 34 | GPIO41/UART3_CTSn |
| PCIe_TX0p | 35 | 36 | GPIO40/UART3_RTSn |
| PCIe_TX0n | 37 | 38 | NI |
| GND | 39 | 40 | MIPI_CSI0_RCKp |
| PCIe_RX0p | 41 | 42 | MIPI_CSI0_RCKn |
| PCIe_RX0n | 43 | 44 | NI |
| GND | 45 | 46 | NI |
| PCIe_CLKp | 47 | 48 | NI |
| PCIe_CLKn | 49 | 50 | CLK32_OUT |
| GND | 51 | 52 | PCIE_PERSTn |
| PCIE_CLKREQ | 53 | 54 | GPIO10/DISABLE_BT |
| PCIE_PEWAKE | 55 | 56 | GPIO09/DISABLE_WiFi |
| GND | 57 | 58 | GPIO46/TW0_SDA(VDDIO_1.8V) |
| PCIe_TX1p | 59 | 60 | GPIO47/TW0_SCL(VDDIO_1.8V) |
| PCIe_TX1n | 61 | 62 | NI |
| GND | 63 | 64 | MIPI_CSI1_RD0p |
| PCIe_RX1p | 65 | 66 | MIPI_CSI1_RD0n |
| PCIe_RX1n | 67 | 68 | MIPI_CSI1_RD1p |
| GND | 69 | 70 | MIPI_CSI1_RD1n |
| MIPI_CSI1_RCKp | 71 | 72 | VCC-NGFF |
| MIPI_CSI1_RCKn | 73 | 74 | VCC-NGFF |
| GND | 75 | ||
Source code on github
Armbian Source code:
- https://github.com/BPI-SINOVOIP/armbian-build/commit/9163a04ca984461bec2516e9be0acd8a990863b9
- https://github.com/BPI-SINOVOIP/armbian-build/tree/v23.12.18
Linux Source code:
- https://github.com/BPI-SINOVOIP/pi-linux/tree/pi-5.4-vs680-hdmi
- https://github.com/BPI-SINOVOIP/pi-u-boot/tree/v2019.10-vs680
- Senary VS680(Synaptics SN3680) datasheet:
- The VS680 NPU is ranked first on AI benchmark website: https://ai-benchmark.com/ranking_IoT.html
- BPI-M6 AI function test: https://www.youtube.com/watch?v=RIO0K_V12D4
- BPI-M6 VS680 SOC System Tool Manual V1.3.2.1
- Baidu Cloud: https://pan.baidu.com/s/1tX7UVSJQOcNhMlazQRQkpw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1gQalGLqNN24TeTBmJGzS0e3HeXxRD1fP/view?usp=sharing
- BPI-M6 schematic diagram
- Baidu Cloud: https://pan.baidu.com/s/18VTAdGtQFb2nu1bku8mHBw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1z-o5dZWcYrmTqNH3Wz9ttWUzptveCS6s/view?usp=sharing
- BPI-M6 DXF File:
- Baidu Cloud: https://pan.baidu.com/s/1Ngc11CcnufAdDcdwMd2mmQ?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1HJmpC5L3YqrJt4IsN0SMD5HoowqfGCyU/view?usp=sharing
- Vergleich Banana Pi Bpi M6 Vs Raspberry Pi 5:https://cool-web.de/raspberry/vergleich-banana-pi-bpi-m6-vs-raspberry-pi-5.htm
- Banana Pi Bpi M6 Raspberry Pi 5 Alternative Ersteinrichtung Firmware Image Hochladen:https://cool-web.de/raspberry/banana-pi-bpi-m6-raspberry-pi-5-alternative-ersteinrichtung-firmware-image-hochladen.htm
- 2023-08-30 release aosp_dolphin_tablet-syna-image-lpddr4x
- Baidu Cloud: https://pan.baidu.com/s/1unEibD-NI8-Ti5le2E6d7g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/file/d/1egPBOusdlNGJDdp5muAjiv2MvMya0F-H/view?usp=sharing
- 2023-12-18-ubuntu-20.04-mate-desktop-vpu-npu-bpi-m6-aarch64-sd.img
- Baidu Cloud: https://pan.baidu.com/s/1sLDT7rs2vPg1m23uAPCKWw?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/file/d/1S5fFriFq1eWU5wneCku9oo4RSCH_LKea/view?usp=sharing
- 2023-12-17-ubuntu-20.04-mate-desktop-vpu-bpi-m6-aarch64-sd.img
- Baidu Cloud: https://pan.baidu.com/s/1T84pVE48kIOJM0_bPrB_fA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1TXwN9A-l4TLys5k3liwmpv1IKeumPVXf/view?usp=sharing
- 2023-12-15-ubuntu-20.04-mate-desktop-bpi-m6-aarch64-sd.img
- Baidu Cloud: https://pan.baidu.com/s/1ZbkQbxi67F4KFJAMHdoYOg?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1bv5C8cSgz6m8ZdaIGLov1GjPG_ahIfS0/view?usp=sharing
- SINOVOIP Aliexpress Shop: https://www.aliexpress.us/item/3256805894958914.html
- BIPAI Aliexpress Shop: https://www.aliexpress.us/item/3256805895088983.html
- Taobao Shop:https://item.taobao.com/item.htm?spm=a213gs.success.result.1.27e34831MXYuie&id=740957817652&qq-pf-to=pcqq.group
