BPI-M4 Berry development board stands as a powerful Single Board Computer (SBC), harnessing the capabilities of the Allwinner H618 System-on-Chip (SoC) to provide developers with impressive performance and a wealth of features. Similar to the Raspberry Pi 4b, the BPI-M4 Berry boasts comparable CPU prowess, 2G LPDDR4 memory and 8G eMMC, integrated WiFi and Bluetooth functionalities, and a familiar 40-pin header layout, alongside 4 USB interfaces and a GbE RJ45 port.
Characterized by its robust performance, versatile features, and remarkable image processing capabilities, stands as an exemplary SBC development platform for professionals within the embedded and computing industries. Equipped with 8GB eMMC flash storage, high-performance decoding and encoding capabilities, and an array of interface options, it caters to a wide spectrum of application domains, including media processing, IoT, and entertainment. Whether catering to novices or seasoned developers, the BPI-M4 Berry development board offers an ideal toolset for realizing creative visions and project objectives.
- Allwinner H618, Quad-core ARM Cortex™-A53 processor
- ARM Mali G31 GPU
- WIFI & Bluetooth
- 2G LPDDR4 RAM
- 8G eMMC flash memory
- 1x USB2.0 Type-C OTG, 5V power supply
- 4x USB2.0 Type-A
- 1x HDMI 2.0a
- 1x 3.5mm Audio & TVE jack socket
- 1x GbE Ethernet port
| Hardware Specification of Banana pi BPI-M4 Berry
| CPU |
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz
| GPU |
ARM Mali G31 GPU
| Memory |
2 GB LPDDR4
| Storage |
8G eMMC flash
| SD card |
MicroSD card slot
| Wireless |
2.4G/5G WiFi and Bluetooth 4.2
| Ethernet |
1x GbE Ethernet port(supports PoE with add-on PoE HAT)
| HDMI |
1x full-size HDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
| Audio |
| IR |
1x CIR
| USB |
4x USB2.0 Type-A HOST, 1x USB2.0 Type-C OTG
| 40-pin header
28 pins GPIO and Power (+5V, +3.3V and GND)
| UART, SPI, TWI/I²C, PWM, PCM/I²S
| Buttons |
Reset, FEL and User
| LED |
Power Status and Activity status
| Power |
5V@3A via USB Type-C
| Size |
85x56 mm
| Weight |
60g
| module |
Raspberry Pi 4B |
Banana Pi BPI-M4 Berry
| CPU |
1.5GHz 4核 BroadcomBCM2711(Cortex A72) |
H618,64 Bit Cortex™-A53 Quad-Core
| GPU |
500 MHz VideoCore Vl |
ARM Mali G31 GPU
| Memory \(SDRAM\) |
1-4GB DDR4 |
2GB LPDDR4(up to 4G)
| Onboard Storage |
MicroSD (TF) card |
MicroSD (TF) card / MMC card slot ,eMMC 8GB
| Network |
10/100/1000 Ethernet |
| Onboard WIFI &BT |
IEEE 802.11a/b/g/n/ac & BT5.0 |
IEEE 802.11a/b/g/n/ac & BT4.2
| Display |
HDMI |
HDMI
| Camera |
N/A |
N/A
| Video Outputs |
2*Micro-HDMI |
"HDMI 2.0a
| 4K@60fps" |
| Audio Output |
2*Micro-HDMI |
3.5 mm Jack and HDMI
| Audino In |
N/A |
N/A
| GPIO |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus |
| Remote |
N/A |
IR reciever
| USB Ports |
2*USB3.0+2USB2.0 |
2 * USB 2.0 1* USB Otg
| Buttons |
N/A |
Reset button, User button, Uboot button
| LED |
Power led Status led |
Power led Status led Wifi led
| Power |
DC 5V/3A |
DC 5V/2A
| Board Size |
88mmx58mm |
88mmx58mm
PIN define
| 40-pin header define and GPIO Alternative Functions Assignments
| Pin Num
Pin Name
ALT0
ALT1
ALT2
ALT3
| 1
3.3V
| 2
5V
| 3
PG16
UART2_RX
TWI4_SDA
| 4
5V
| 5
PG15
UART2_TX
TWI4_SCK
| 6
GND
| 7
PG19
PWM1
| 8
PG6
UART1_TX
| 9
GND
| 10
PG7
UART1_RX
| 11
PH2
UART5_TX
PWM2
| 12
PG11
H_I2S2_BCLK
| 13
PH3
UART5_RX
PWM1
| 14
GND
| 15
PG2
| 16
PG8
UART1_RTS
| 17
3.3V
| 18
PG9
UART1_CTS
| 19
PH7
UART2_RTS
H_I2S3_LRCK
SPI1_MOSI
| 20
GND
| 21
PH8
UART2_CTS
H_I2S3_DOUT0
SPI1_MISO
H_I2S3_DIN1
| 22
PG1
| 23
PH6
UART2_RX
H_I2S3_BCLK
SPI1_CLK
| 24
PH5
UART2_TX
H_I2S3_MCLK
SPI1_CS0
| 25
GND
| 26
PH9
H_I2S3_DIN0
SPI1_CS1
H_I2S3_DOUT1
| 27
PG18
UART2_CTS
TWI3_SDA
| 28
PG17
UART2_RTS
TWI3_SCK
| 29
PG3
| 30
GND
| 31
PG4
| 32
PG0
| 33
PG5
| 34
GND
| 35
PG12
H_I2S2_LRCK
| 36
PH4
| 37
PG10
H_I2S2_MCLK
| 38
PG14
H_I2S2_DIN0
H_I2S2_DOUT1
| 39
GND
| 40
PG13
H_I2S2_DOUT0
H_I2S2_DIN1
BPI-M4 Berry Debug UART
| 1 |
GND
| 2 |
UART0_RX
| 3 |
UART0_TX
- Baidu Cloud: https://pan.baidu.com/s/1qS-_3d3IpoMBWJe8aI8JFA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/13wsY0cMZGfz5MdTqlo19DtmlZfdOGLI4/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/10Rk4xLMOhIkk-gIoQx9DQw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1N6oWF9PHTcxXC1JY4x3Malr3twFv2wWZ/view?usp=sharing
- 2023-11-09 Bpi-m4berry_0.0.1_beta_ubuntu_jammy_minimal_linux6.1.31
- Baidu Cloud: https://pan.baidu.com/s/1Mh8E6Zh-x8dAPkb00iX9Rw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/159Y7p8j067snqTG4oaUA2CP4aY4t6uyt/view?usp=sharing
- 2023-11-09 Bpi-m4berry_0.0.1_beta_ubuntu_jammy_desktop_xfce_linux6.1.31
- Baidu Cloud: https://pan.baidu.com/s/1_sN137hKZt4DaawVsfO5Nw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/10wXnsgGtLWwf9J-dvLHW2mxsPKOrdHmJ/view?usp=sharing
- SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006212355480.html?spm
- Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006212128000.html?gatewayAdapt=glo2usa
- Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.11.489155c8Addsck&id=747425760994
