Getting Started with BPI-R4
* Prepare 8G/above TF card, USB-Serial cable, Ubuntu System * Using your USB-Serial cable Connect to debug console on BPI-R4 G=GND; RX=BPI-R4 input; TX=BPI-R4 output![]()
* BPI-R4 bootstrap and device select Jumper Setting![]()
* Examples:
1. All Jumper is "1", BPI-R4 will boot from SD card![]()
2. SW3-A is "0" and SW3-B is "1" , BPI-R4 will boot from SPI NAND![]()
3. SW3-A is "1" and SW3-B is "0" , BPI-R4 will boot from eMMC![]()
4. If the console said "system halt!", it means that the bootup storage does not cotain any OS![]()
Accessories
1. 10G SFP Module
The SFP serdes of BPI-R4 requesting link mode inband/10gbase-kr, so only SFP that support this protocol can be used!
10G SFP+ Copper Module
Note:
