Getting Started with BPI-M4 Berry
Revision as of 03:46, 23 October 2023 by Wind (talk | contribs) (→Start)
1. Linux image support SDcard or EMMC bootup, but you should read the [Boot_Sequence boot sequence] at first.
3. Make sure bootable EMMC is formatted if you want bootup from SDcard.
5. Download latest [Linux Linux Image], and confirm that the md5 checksum is correct.
7. The wiki guide is only for [bananapi 4.9 bsp ubuntu/debian images].
Install Image to SDcard
2. Install Image with Balena Cli on Windows, Linux and MacOS.
 sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip
 sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2
 sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2 --yes
3. Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 sudo apt-get install pv unzip
 sudo unzip -p xxx-bpi-m4-berry-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
4. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
 sudo bpi-copy xxx-bpi-m4-berry-xxx.img.zip /dev/sdX
Ubuntu Desktop
1. Using the Ubuntu desktop version system image, you can get a graphical operation interface.
2. You need to prepare a monitor with an HDMI interface and an HDMI cable.
3. Use an HDMI cable to connect the monitor and BPI-M4 Berry, switch the monitor input interface to the corresponding HDMI interface, power on, and wait a moment to see the desktop.
Debug UART
1. Prepare a 3.3v USB to TTL module.
2. Use the USB to TTL module to connect the PC USB port and the Debug UART port on the board.
3. Open a serial terminal software on the PC, such as mobaxterm or putty.
4. Taking mobaxterm as an example, after setting the serial port number and 115200 baud rate, you can open the BPI-M4 Berry UART terminal.
SSH
1. Prepare a network cable and a router.
2. Use a network cable to connect the LAN port of the router to the BPI-M4 Berry, and also connect the PC to another LAN port.
3. Check the IP address of BPI-M4 Berry on the router management interface, or use the following command on the BPI-M4 Berry UART terminal to check the IP address.
  ifconfig
        device interrupt 42
4. Open an SSH terminal software on the PC, such as mobaxterm or putty.
5. Taking mobaxterm as an example, fill in the obtained IP address, such as 192.168.3.10 above, in the IP address column and 22 in the Port port.
6. Open the SSH terminal and enter the login username/password: pi/bananapi or root/bananapi. There will be no prompt when entering the password. Please enter it normally and press Enter when finished.
NoMachine Remote Desktop
1. Make sure BPI-M4 Berry is connected to the Internet and use the following command to download the nomachine DEB installation package in the system.
2. Or open NoMachine for ARM - arm64 download page in a PC browser, download the DEB installation package, and then copy it to BPI-M4 Berry user directory through SSH or USB disk.
3. After the download is completed, install it through the following command. Note that the file name is based on the actual downloaded file name.
4. PC side also needs to download and install NoMachine. NoMachine download page Select the installation package suitable for the PC operating system, download it locally and complete the installation.
5. Pay attention to keeping the PC and BPI-M4 Berry in the same LAN. You can try SSH connection first to ensure normal communication within the LAN.
6. Open NoMachine on the PC, click the Add button, enter the IP address of BPI-M4 Berry in the Host bar in the window after the jump, and then click the Add button.
7. Click the recognized port icon, enter the username/password in the new window that pops up, and then click the OK button.
8. After completing the subsequent settings, you can see the desktop.
9. If no device is connected to the HDMI interface, the NoMachine remote desktop will display a black screen. It is recommended to keep the HDMI connection or connect an HDMI decoy device.
WiFi
Use the nmcli command to scan WiFi hotspots, connect to hotspots, and create AP hotspots.
  nmcli device #List devices
  nmcli device wifi list # List available wifi access points, list can be omitted
  nmcli device wifi connect [SSID] password [PASSWORD] # Connect to the hotspot mySSID. After the connection is successful, the configuration file will be automatically generated. If you want to connect again in the future, you can use the nmcli connection up [SSID] command.
  nmcli device disconnect [device name] # Disconnect wifi, use the wifi device name displayed in the nmcli device command
  nmcli device wifi hotspot con-name [NAME] ifname [device name] ssid [SSID] password [PASSWORD] # Create AP hotspot
  nmcli connection show #List network connection configuration
  nmcli connection down [NAME] # Activate a connection
  nmcli connection up [NAME] # Deactivate a connection
  nmcli connection delete [SSID] #Delete a configuration and no longer save information and automatically connect
  nmcli radio wifi off # Turn off wifi
  nmcli radio wifi on # Turn on wifi
Set static IP, DNS
1. To set a static IP, you need to maintain the connection first. If you want to set an Ethernet static IP, you must first maintain the Ethernet connection; if you want to set a wireless network static IP, you must first maintain a connection to a WIFI.
2. If the upper-level router has assigned the IP address you want to set to other devices, please change it to an idle IP, or ask other devices to give up the IP.
3. Use the nmcli connection show command to display all connections, for example:
  pi@bpi-m4berry:~$ nmcli connection show
  NAME UUID TYPE DEVICE
  TP-LINK_5G_7747 e4a49726-adf1-44d7-a621-0e3af96cc390 wifi wlx2cc3e6acd5d7
  Wired connection 1 612eda94-55dc-3c85-b05e-f16c41775b4e ethernet --
4. Use the nmcli connection show [NAME] command to display all the properties of a specific connection, such as:
  #Only list three common items
  ipv4.dns: 192.168.3.1 #The default is the gateway address
  ipv4.addresses: 192.168.3.10/24 #The default is the IP address assigned by the router DHCP
  ipv4.gateway: 192.168.3.1 #Gateway address, the default is the IP address of the router
5.Set static IP:
6.Set DNS:
7.Reset:
  reboot
8. After restarting, check whether the modification is successful:
  ifconfig
Network time synchronization
Chrony is an open source free Network Time Protocol NTP client and server software. It allows the computer to keep the system clock synchronized with the clock server (NTP), thus allowing your computer to maintain accurate time. Chrony can also be used as a server software to provide time synchronization services for other computers.
  sudo apt install chrony #Install chrony
  systemctl start chrony #Start chrony
  systemctl enable chrony
  systemctl status chrony
  systemctl restart chrony #Restart service
  timedatectl status #View time synchronization status
  timedatectl list-timezones #View time zone list
  timedatectl set-timezone Asia/Shanghai #Modify time zone
  timedatectl set-ntp true #Enable NTP network time synchronization
  date #View time
  sudo hwclock -r #View hardware clock
View hardware temperature
  sensors
Modify HDMI output resolution
When using the Ubuntu desktop operating system, you can find the Displays column in Settings and modify the resolution.
Use USB disk
1. Prepare a USB disk that has been partitioned normally and insert it into the USB interface of BPI-M4 Berry.
2. In the Ubuntu desktop version, you can see that the USB flash drive has been recognized and can be opened in the file manager, or partition management can be performed through the GParted tool.
3. In the terminal, mount the USB disk to the local directory:
  mkdir mnt #Create a separate directory in the ~/user directory for mounting for easy management
  cat /proc/partitions | grep "sd*" #List partitions starting with sd
  sudo mount /dev/sda1 ~/mnt/ #Mount /dev/sda1 to ~/mnt/
  ls ~/mnt/ #After mounting, you can list the files in the USB disk
  sudo umount -v /dev/sda1 #umount, then you can remove the USB disk
Use Audio Devices
Prepare an audio file and copy it to the BPI-M4 Berry Ubuntu desktop system through a USB flash drive or SSH.
HDMI Audio
1. Prepare a monitor with HDMI audio input function, turn on the relevant functions in the monitor settings, and use an HDMI cable to connect the monitor.
2. Set the output device to HDMI Audio in the Sound column of the settings.
3.Play audio.
3.5mm audio interface
1. Prepare a headset or other audio device that uses a 3.5mm plug, insert the plug into the 3.5mm jack of BPI-M4 Berry.
2. Set the output device to Audio Codec in the Sound column of the settings.
3. Play audio.
Use Bluetooth
1. Open settings in the Ubuntu desktop and connect a Bluetooth device, such as a Bluetooth mouse or keyboard, in the Bluetooth bar.
2. The method to connect the Bluetooth device through the command line in the terminal is as follows:
pi@bpi-m4berry:~$ sudo bluetoothctl #Open the Bluetooth device management tool
[sudo] password for pi:
Agent registered
[CHG] Controller 2C:C3:E6:AC:D5:D8 Pairable: yes
[bluetooth]# power on #Start the Bluetooth function, power off to turn it off
Changing power on succeeded
[bluetooth]# discoverable on #Allow this device to be discovered
Changing discoverable on succeeded
[CHG] Controller 2C:C3:E6:AC:D5:D8 Discoverable: yes
[bluetooth]# pairable on #Allow device pairing
Changing pairable on succeeded
[bluetooth]# scan on #Start scanning
Discovery started
[CHG] Controller 2C:C3:E6:AC:D5:D8 Discovering: yes
[NEW] Device D4:C4:85:A5:C6:B1 Logitech Pebble #The MAC address and device name of a Bluetooth mouse
[CHG] Device D4:C4:85:A5:C6:B1 TxPower: 4
[bluetooth]# pair D4:C4:85:A5:C6:B1 #Pair the MAC address of the Bluetooth device you want to connect to
Attempting to pair with D4:C4:85:A5:C6:B1
[CHG] Device D4:C4:85:A5:C6:B1 Connected: yes
[DEL] Device A4:C1:38:9B:F6:FD SLPO20N20200059
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 0000180a-0000-1000-8000-00805f9b34fb
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 0000180f-0000-1000-8000-00805f9b34fb
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001812-0000-1000-8000-00805f9b34fb
[CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00010000-0000-1000-8000-011f2000046d
[CHG] Device D4:C4:85:A5:C6:B1 ServicesResolved: yes
[CHG] Device D4:C4:85:A5:C6:B1 Paired: yes
Pairing successful #pairing successfully
[CHG] Device D4:C4:85:A5:C6:B1 Modalias: usb:v046DpB021d0007
[bluetooth]# exit #Exit the Bluetooth device management tool
pi@bpi-m4berry:~$
archlinux bluetooth reference document
Use IR Receiver
1. You need to prepare an infrared remote control using NEC format.
2. Enter the following command in the terminal to start receiving infrared signals.
  sudo ir-keytable -c -p NEC -t
  Old keytable cleared
  Protocols changed to nec
  Testing events. Please, press CTRL-C to abort.
  258.553895: lirc protocol(nec): scancode = 0x45
  258.553926: event type EV_MSC(0x04): scancode = 0x45
  258.553926: event type EV_SYN(0x00).
  260.667648: lirc protocol(nec): scancode = 0x46
  260.667671: event type EV_MSC(0x04): scancode = 0x46
  260.667671: event type EV_SYN(0x00).
  260.719552: lirc protocol(nec): scancode = 0x46 repeat
  260.719568: event type EV_MSC(0x04): scancode = 0x46
  260.719568: event type EV_SYN(0x00).
  273.263728: lirc protocol(nec): scancode = 0x47
  273.263753: event type EV_MSC(0x04): scancode = 0x47
  273.263753: event type EV_SYN(0x00).
  273.315591: lirc protocol(nec): scancode = 0x47 repeat
  273.315608: event type EV_MSC(0x04): scancode = 0x47
  273.315608: event type EV_SYN(0x00).
Transfer files
scp
The scp command format is:
1.[optionals] is an optional parameter, such as -r, which can be used to copy the entire directory recursively.
2.file_source The file or directory to be copied.
3.file_target will copy the past path and rename it if a specific file name is entered at the end.
PS D:\temp\temp_4> scp ".\hello.txt" [email protected]:"/home/pi/Downloads/"
PS D:\temp\temp_4> scp [email protected]:"/home/pi/Downloads/hello.txt" "D:\temp\temp_4"
Where [email protected] is the user name in the Linux system and the IP address of the BPI-M4 Berry in the LAN.
Where :"/home/pi/Downloads/hello.txt" is the file path in the Linux system.
Where "D:\temp\temp_4" is the path in Windows system.
scp reference document
mobaxterm
mobaxterm download
mobaxterm-linux preview version
