Getting Started with BPI-M4 Berry
- 1. Linux image support SDcard or EMMC bootup, but you should read the [Boot_Sequence boot sequence] at first.
- 3. Make sure bootable EMMC is formatted if you want bootup from SDcard.
- 5. Download latest [Linux Linux Image], and confirm that the md5 checksum is correct.
- 7. The wiki guide is only for [bananapi 4.9 bsp ubuntu/debian images].
Install Image to SDcard
sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2 sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2 --yes
sudo apt-get install pv unzip sudo unzip -p xxx-bpi-m4-berry-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 4. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
sudo apt-get install pv unzip sudo bpi-copy xxx-bpi-m4-berry-xxx.img.zip /dev/sdX
Start
Ubuntu Desktop
- 1. Using the Ubuntu desktop version system image, you can get a graphical operation interface.
- 2. You need to prepare a monitor with an HDMI interface and an HDMI cable.
- 3. Use an HDMI cable to connect the monitor and BPI-M4 Berry, switch the monitor input interface to the corresponding HDMI interface, power on, and wait a moment to see the desktop.
Debug UART
- 1. Prepare a 3.3v USB to TTL module.
- 2. Use the USB to TTL module to connect the PC USB port and the Debug UART port on the board.
- 3. Open a serial terminal software on the PC, such as mobaxterm or putty.
- 4. Taking mobaxterm as an example, after setting the serial port number and 115200 baud rate, you can open the BPI-M4 Berry UART terminal.
SSH
- 1. Prepare a network cable and a router.
- 2. Use a network cable to connect the LAN port of the router to the BPI-M4 Berry, and also connect the PC to another LAN port.
- 3. Check the IP address of BPI-M4 Berry on the router management interface, or use the following command on the BPI-M4 Berry UART terminal to check the IP address.
ifconfig
device interrupt 42
- 4. Open an SSH terminal software on the PC, such as mobaxterm or putty.
- 5. Taking mobaxterm as an example, fill in the obtained IP address, such as 192.168.3.10 above, in the IP address column and 22 in the Port port.
- 6. Open the SSH terminal and enter the login username/password: pi/bananapi or root/bananapi. There will be no prompt when entering the password. Please enter it normally and press Enter when finished.
NoMachine Remote Desktop
- 1. Make sure BPI-M4 Berry is connected to the Internet and use the following command to download the nomachine DEB installation package in the system.
- 2. Or open NoMachine for ARM - arm64 download page in a PC browser, download the DEB installation package, and then copy it to BPI through SSH or USB disk -M4 Berry user directory.
- 3. After the download is completed, install it through the following command. Note that the file name is based on the actual downloaded file name.
- 4. PC side also needs to download and install NoMachine. NoMachine download page Select the installation package suitable for the PC operating system, download it locally and complete the installation.
- 5. Pay attention to keeping the PC and BPI-M4 Berry in the same LAN. You can try SSH connection first to ensure normal communication within the LAN.
- 6. Open NoMachine on the PC, click the Add button, enter the IP address of BPI-M4 Berry in the Host bar in the window after the jump, and then click the Add button.
- 7. Click the recognized port icon, enter the username/password in the new window that pops up, and then click the OK button.
- 8. After completing the subsequent settings, you can see the desktop.
WiFi
- Use the nmcli command to scan WiFi hotspots, connect to hotspots, and create AP hotspots.
nmcli device #List devices nmcli device wifi list # List available wifi access points, list can be omitted nmcli device wifi connect [SSID] password [PASSWORD] # Connect to the hotspot mySSID. After the connection is successful, the configuration file will be automatically generated. If you want to connect again in the future, you can use the nmcli connection up [SSID] command. nmcli device disconnect [device name] # Disconnect wifi, use the wifi device name displayed in the nmcli device command nmcli device wifi hotspot con-name [NAME] ifname [device name] ssid [SSID] password [PASSWORD] # Create AP hotspot
nmcli connection show #List network connection configuration nmcli connection down [NAME] # Activate a connection nmcli connection up [NAME] # Deactivate a connection nmcli connection delete [SSID] #Delete a configuration and no longer save information and automatically connect
nmcli radio wifi off # Turn off wifi nmcli radio wifi on # Turn on wifi
Network time synchronization
- Chrony is an open source free Network Time Protocol NTP client and server software. It allows the computer to keep the system clock synchronized with the clock server (NTP), thus allowing your computer to maintain accurate time. Chrony can also be used as a server software to provide time synchronization services for other computers.
sudo apt install chrony #Install chrony systemctl start chrony #Start chrony systemctl enable chrony systemctl status chrony systemctl restart chrony #Restart service
timedatectl status #View time synchronization status timedatectl list-timezones #View time zone list timedatectl set-timezone Asia/Shanghai #Modify time zone timedatectl set-ntp true #Enable NTP network time synchronization
date #View time sudo hwclock -w #Set hardware clock sudo hwclock -s #Set the system clock sudo hwclock -r #View hardware clock
