- 1. Linux image support SDcard or EMMC bootup, but you should read the [Boot_Sequence boot sequence] at first.
- 3. Make sure bootable EMMC is formatted if you want bootup from SDcard.
- 5. Download latest [Linux Linux Image], and confirm that the md5 checksum is correct.
- 7. The wiki guide is only for [bananapi 4.9 bsp ubuntu/debian images].
Install Image to SDcard
$ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip
$ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2
$ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2 --yes
$ sudo unzip -p xxx-bpi-m4-berry-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 4. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo bpi-copy xxx-bpi-m4-berry-xxx.img.zip /dev/sdX
custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo
ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo
hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo
hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo
i2c0.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo
i2c1.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo
pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
- 2. Update the overlays env in vfat /boot/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
# Overlays to load
# Example combinations:
# spi0 i2c0 i2c1 uart0
# hktft32
# hktft35
$ sudo apt-get update
$ cd amlogic-wiringPi
$ chmod a+x build
$ sudo ./build
$ cd RPi.GPIO-Amlogic
WiringPi2-Python
$ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git
$ cd WiringPi2-Python-Amlogic
Luma.Examples
$ sudo python3 test/led.py
$ sudo groupadd --system xxx
$ cd luma.examples
$ sudo -H pip install -e .
- or
$ sudo -H pip3 install -e .
Using UNIX configuration...
$ pip3 list | grep luma
luma.core 2.4.0
luma.emulator 1.4.0
luma.lcd 2.10.0
luma.led-matrix 1.7.0
luma.oled 3.11.0
- 3. examples test
$ cd examples
Enable sudo for Debian
$ su root
Password:(enter bananapi)
# apt-get update
# apt-get install sudo
# adduser pi sudo
