Getting Started with BPI-M4 Berry
Revision as of 09:25, 27 September 2023 by Wind (talk | contribs)
1. Linux image support SDcard or EMMC bootup, but you should read the [Boot_Sequence boot sequence] at first.
3. Make sure bootable EMMC is formatted if you want bootup from SDcard.
5. Download latest [Linux Linux Image], and confirm that the md5 checksum is correct.
7. The wiki guide is only for [bananapi 4.9 bsp ubuntu/debian images].
Install Image to SDcard
2. Install Image with Balena Cli on Windows, Linux and MacOS.
 $ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip
 $ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2
 $ sudo balena local flash path/to/xxx-bpi-m4-berry-xxx.img.zip --drive /dev/disk2 --yes
3. Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 $ sudo unzip -p xxx-bpi-m4-berry-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
4. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
 $ sudo bpi-copy xxx-bpi-m4-berry-xxx.img.zip /dev/sdX
2. Update the overlays env in vfat /boot/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
 # Overlays to load
 # Example combinations:
 #   spi0 i2c0 i2c1 uart0
 #   hktft32
 #   hktft35
 $ sudo apt-get update
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
 $ cd RPi.GPIO-Amlogic
Create and install wheel package
Install from git source directly without development
If the package is already installed, it should be uninstalled before installing the new one, or installing the new one with --force-reinstall option.
WiringPi2-Python
 $ cd WiringPi2-Python-Amlogic
Luma.Examples
1. build and install RPi.GPIO
you can change the bcmledpin variable in test/led.py to your hardware backlight gpio and run it to check RPi.GPIO works well.
 $ sudo python3 test/led.py
hardware backlight will repeat on and off
2. luma.examples libs install
if group does not exist, the following command will create it:
 $ sudo groupadd --system xxx
 $ cd luma.examples
install luma.core, luma.emulator, luma.lcd, luma.le-matrix, luma.oled pip libs, make sure this step without error or downloading interrupted, try again if get errors
 $ sudo -H pip install -e .
or
 $ sudo -H pip3 install -e .
for debian buster(python 3.7) which does not include /usr/bin/pip in package python3-pip, and will get the following errors when install luma packages with pip3
 Using UNIX configuration...
install sdl2 related packages to fix this issue, then install luma libs again with pip3
check installed luma pip libs
 $ pip3 list | grep luma
   luma.core          2.4.0
   luma.emulator      1.4.0
   luma.lcd           2.10.0
   luma.led-matrix    1.7.0
   luma.oled          3.11.0
3. examples test
 $ cd examples
Enable sudo for Debian
 $ su root
 Password:(enter bananapi)
 # apt-get update
 # apt-get install sudo
 # adduser pi sudo
