Banana Pi BPI-M2+
Revision as of 19:36, 26 September 2023 by Sinovoip (talk | contribs) (Easy to buy)
Banana Pi BPI-M2+ with Allwinner H3 chip
Banana Pi BPI-M1 with Allwinner A20 chip
Banana Pi BPI-M1+ with Allwinner A20 chip
Banana Pi BPI-P2 Zero with Allwinner H3 chip
Banana Pi BPI-M2M with Allwinner R16 chip design
Banana Pi BPI-M2 Berry with Allwinner A40i
Banana Pi BPI-M2U with Allwinner A40i
Banana Pi BPI-M64 with Allwinner A64 chip design
Banana Pi BPI-M3 with Allwinner A83T chip design
Overview:3D design
Case BPI-M2+ Premium Aluminum Enclosure
BPI-4.0 OEM&ODM Successful case:H3 for eBlocker VPN router
Banana Pi BPI-M2 Pro S905x3 design,same size and inerface as BPI-M2+
Banana PI BPI-M2+ is the open source hardware platform, use Alliwnner H3 (option H2+ chip and H5 chip ) chip on board. and mini size only 65mm*65mm,
  • Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
  • 1GB DDR3
  • 8GB eMMC onboard
  • HDMI out
  • WiFi and BT onboard
  • CSI camera interface
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
WIFI&BT K016/SDIO AP6212 for Wifi &BT 4.0(option AP6181 AP6335)
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
Uart PIN of Banana pi BPI-M2+
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
Hardware V1.2 Version
BPi-M2+ V1.2 modification
  • 1,PL0 Instead the drop-down 10K,As a hardware version identification(V1.1 is pull up)
  • 2,PL1 Change to voltage regulation GPIO
OpenCV 3.4x on BananaPi
source code
documents
google drive: google driver
baidu cloud : https://pan.baidu.com/s/1vjBURLzFF2LYCe8CBcs9Mg
Android 7.0
how to install : http://setordigital.blogspot.com/2017/01/como-instalar-o-android-no-orange-pi.html
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2-new-image-android-7-0-nougat-2018-10-20/7082
  • Image Link:
Google Drive : https://drive.google.com/file/d/1TY4CgFxCT3pR6S2nw5w-_XkNsW9fPBhI
Baidu Drive : https://pan.baidu.com/s/1ETpbauIezp1228n7kdWo4A
Forum thread: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-image-android7-0-release-2018-6-30/6147
How to Google registration: https://www.google.com/android/uncertified/ Android7.0 needs to register devices by youself
Android 4.4
  • Image Link:
Baidu Drive: https://pan.baidu.com/s/1gfr7vJ9
Forum thread: http://forum.banana-pi.org/t/bpi-m2-new-image-android-4-4-version-v3/2765
H3Droid android
forum pthread:http://forum.banana-pi.org/t/h3droid-android-development-on-allwinner-h3-chip-project/3459/14
  • 2020-04-23 update, Ubuntu 16.04 Mate Desktop, Ubuntu 16.04 Server, Debian 9 and Raspbian Stretch images, base on kernel 4.4
google drive :https://drive.google.com/drive/folders/0B_YnvHgh2rwjNExjUmlRNXdVNUE
baidu cloud: https://pan.baidu.com/s/1Tay4F7nJJV1MzI_aO4NjHw pincode:ih9p
  • 2022-09-07 Armbian_22.11.0-trunk_Bananapim2zero_jammy_edge_5.19.6_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/1-BXzCnnXr9NvOsfBr646ZGOicQ7Kv9-o/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/19xg6YfySrUR6jclXYrzdOg?pwd=qfys (pincode: qfys)
  • Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10
google drive: https://drive.google.com/drive/folders/1DEO7JdMfDhHynC83K7JMxgnNxf1gV82S
  • 2018-5-17 update : Ubuntu 16.04 V1.1 new eMMC and PMU support, base on kernel 3.4
Image Link:
Forum thread:
  • 2017-07-14 update : ubuntu-16.04-mate-desktop, base on kernel 3.4
Image Link:
Forum thread:
  • 2018-11-09 update ,This release is for banana pi M2P board which is based on Allwinner H3, We release three images, Ubuntu 16.04, Raspbian 9 and Debian 9, base on kernel 4.4.
M2P Ubuntu 16.04
Features Map:http://wiki.banana-pi.org/M2P-H3_Image_Map#Kernel_4.4.55
Google Drive : https://drive.google.com/file/d/1dgrtVqbR4I6xYlSfWBJeGwh8xI79L1PD/view?usp=sharing
Baidu Drive : https://pan.baidu.com/s/1RHZ-b7PcY9ybeiy95C_VIg
md5sum : 59f2cc29ce045c15e51fac20ff6924aa
forum pthread: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-demo-images-release-with-kernel-4-4-2018-11-09/7210
  • 2018-01-02 update : Ubuntu image, base on Kernel 4.4
Forum thread:
http://forum.banana-pi.org/t/bpi-m2-new-image-bpi-m2-kernel-4-4-55/4577
Armbian image
  • Armbain have support BPI-M2+,Armbian Bionic and Armbian Stretch version
Image download : https://www.armbian.com/banana-pi-m2-plus/
Armbin image download: https://www.armbian.com/banana-pi-m2-plus/
  • Image from Banana Pi team, released on 2023-07, Armbian_23.02.0
Baidu Cloud: https://pan.baidu.com/s/1v0JVs50LCqLuioi9I7fGpw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1f_EuiwpfDbBmwa5F5jUqjpGu9hFM9c2-?usp=sharing
  • Image from Banana Pi team, released on 2023-07, Armbian_23.08.0
Baidu Cloud: https://pan.baidu.com/s/1UMfEkiWdsnV4Lun0wbu17A?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1VGO4iysut1PHOBCc2J5XMGjSo7OJDHTw?usp=sharing
  • Armbian_23.02.0-trunk_Bananapim2plus_bullseye_current_5.15.93.img.xz
  • Armbian_23.02.0-trunk_Bananapim2plus_bullseye_edge_6.0.10_xfce_desktop.img.xz
  • Armbian_23.02.0-trunk_Bananapim2plus_jammy_edge_6.1.11_xfce_desktop.img.xz
https://pan.baidu.com/s/1hkkl22uVjvRct1V7N4OK2w?pwd=8888
https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2-plus-new-armbian-image/15160
  • 2022-12-06 Armbian_22.11.0-trunk_Bananapim2plus_bullseye_edge_6.0.9.img.xz
Google Drive:https://drive.google.com/file/d/1xnyen2FlP3b5kpIC8C70fIT2RUPaeQxo/view?usp=share_link
Baidu Cloud:https://pan.baidu.com/s/11z-4c1Gj74D7hrT7R-_xhg?pwd=8888 (pincode: 8888)
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-plus-new-image-release-armbian-bullseye/14449
  • Armbian 5.51 debin Bananapi-m2+ build by BPI 2018-07-12
Google download : https://drive.google.com/open?id=1H_KEVWTRwgSgal5gt8jKqBT-y4IqIX84
Baidu download : https://pan.baidu.com/s/1OaBRKHPGqjgat0mntHyYxg
Discuss on forum : http://forum.banana-pi.org/t/bpi-m2-new-image-2018-07-12-armbian-5-51-debin-bananapi-m2-build-by-bpi-2018-07-12/6265
Openelec Kodi
  • Openelec Kodi 16.0 (xbmc)
Debian linux
  • 2022-09-07 Armbian_22.11.0-trunk_Bananapim2plus_bullseye_edge_5.19.6_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/17j0YW8SJKpOG2YKRCuGLKXYHuq1wLSAh/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1prE9mlVuErHidWNJFynKzA?pwd=8ikd (pincode: 8ikd)
  • 2019-09-18 update,Banana Pi BPI-M2+ boot debian 10 with grub (u-boot-2019.07 + kernel 5.1.1)
google drive: https://drive.google.com/file/d/1ZQx732W8u83LECsFqCT9DtEPiQati-z6/view?usp=sharing
  • 2018-11-09 update ,This release is for banana pi M2P board which is based on Allwinner H3, We release three images, Ubuntu 16.04, Raspbian 9 and Debian 9 with kernel 4.4.
M2P Debian 9 Features Map :http://wiki.banana-pi.org/M2P-H3_Image_Map#Kernel_4.4.55_2
Google Drive : https://drive.google.com/file/d/13HTp2smKPPK_4byHCI_T3Atg8_NfyQ5S/view?usp=sharing
Baidu Drive : https://pan.baidu.com/s/1h3TSAzY8ootahOjxkoTG1Q
md5sum : f979f1a68d759e804e0a90654f4577f1
forum pthread :http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-demo-images-release-with-kernel-4-4-2018-11-09/7210
Raspbian
M2P Raspbian 9 Features Map:http://wiki.banana-pi.org/M2P-H3_Image_Map#Kernel_4.4.55_3 1
Google Drive :https://drive.google.com/open?id=182a1iSYyW8UMJHOyzbu35RfLi-Wn5H8h
Baidu Drive : https://pan.baidu.com/s/1g5Suk-Ybd3jdhdX82llBwg
md5sum : 53ec3986ec3df84fa2548d0742f700fa
fourm pthread :http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-demo-images-release-with-kernel-4-4-2018-11-09/7210
  • 2018-5-22 update : Raspbian jessie 8.0 kernel 3.4
Image Link:
baidu cloud :https://pan.baidu.com/s/16KJbtwjT_PBCZJkYV79_ag
Forum thread:
  • 2018-5-22 update : Raspbian 8.0 V1.1 new eMMC and PMU
Image Link:
Forum thread:
OpenSUSE
  • OpenSUSE have official support Banana Pi BPI-M2+
image download : http://download.opensuse.org/ports/armv7hl/factory/images/
FreeBSD
Lakka TV
Dietpi
RetroPie
retrorangepi
Others image
