Banana Pi BPI-M3
[hide]Introduction
- Allwinner A83T Octa-core 1.8GHz Powerful CPU.
- 2 GB LPDDR3 memory.
- 8 GB eMMC storage.
- HDMI out
- IR control
- WiFi & Bluetooth onboard.
- MIPI DSI ingerface
- CSI camera interface
- How to burn image to BPI-M3 and begin Quick Start Banana pi SBC
- How to development Getting Start with M3
Banana Pi BPI-M3 | |
CPU | Allwinner A83T ARM Cortex-A7 Octa-Core 1.8 GHz, 512KB L1 cache and 1MB L2 cache |
GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory | 2 GB LPDDR3 (shared with GPU) |
Storage | On Board 8GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port (USB-to-SATA bridge) |
Network | 10/100/1000 Mbit/s Ethernet (Realtek RTL8211E/D) + Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | HDMI 1.4 (Type A Full), MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack and HDMI |
USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
Remote | IR Receiver (x1) |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Size & Weight | 92x60mm, 48g |
OS | Android and Linux |
40 PIN GPIO define of Banana pi BPI-M3 | |||
CON1-P01 | VCC-3V3 | ||
CON1-P02 | DCIN | ||
CON1-P03 | TWI2-SDA | PH5-EINT5 | |
CON1-P04 | DCIN | ||
CON1-P05 | TWI2-SCK | PH4-EINT4 | |
CON1-P06 | GND | ||
CON1-P07 | S-PWM | PL10-S-EINT10 | |
CON1-P08 | UART2-TX | PB0-EINT0 | |
CON1-P09 | GND | ||
CON1-P10 | UART2-RX | PB1-EINT1 | |
CON1-P11 | PC4 PC4 | ||
CON1-P12 | UART2-CTS | PB3-EINT3 | |
CON1-P13 | PC7 | PC7 | |
CON1-P14 | GND | ||
CON1-P15 | PC17 | PC17 | |
CON1-P16 | UART2-RTS | PB2-EINT2 | |
CON1-P17 | VCC-3V3 | ||
CON1-P18 | PL8-ENT8 | PL8-S-ENT8 | |
CON1-P19 | SPI0_MOSI | PC0 | |
CON1-P20 | GND | ||
CON1-P21 | SPI0_MISO | PC1 | |
CON1-P22 | PL9-EINT9 | PL9-S-EINT9 | |
CON1-P23 | SPI0_CLK | PC2 | |
CON1-P24 | SPI0_CS | PC3 | |
CON1-P25 | GND | ||
CON1-P26 | PH10-ENT10 | PH10-ENT10 | |
CON1-P27 | TWI1-SDA | PH3-EINT3 | |
CON1-P28 | TWI1-SCK | PH2-EINT2 | |
CON1-P29 | PC18 | PC18 | |
CON1-P30 | GND | ||
CON1-P31 | I2S1-BCLK | PG10-EINT10 | UART3-TX |
CON1-P32 | I2S1-DIN | PG13-EINT13 | UART3-CTS |
CON1-P33 | I2S1-LRCK | PG11-EINT11 | UART3-RX |
CON1-P34 | GND | ||
CON1-P35 | I2S1-DOUT | PG12-EINT12 | UART3-RTS |
CON1-P36 | PE5 | PE5 | |
CON1-P37 | PE4 | PE4 | |
CON1-P38 | OWA-DOUT | PE18 | |
CON1-P39 | GND | ||
CON1-P40 | PE19 | PE19 |
CSI camera GPIO of Banana pi BPI-M3 | |||
CN7-P01 | IPSOUT | ||
CN7-P02 | AFVCC | ||
CN7-P03 | IPSOUT | ||
CN7-P04 | IOVDD | ||
CN7-P05 | GND | ||
CN7-P06 | GND | ||
CN7-P07 | CSI2-D3N | ||
CN7-P08 | AVDD-CSI | ||
CN7-P09 | CSI2-D3P | ||
CN7-P10 | DVDD-CSI-R | ||
CN7-P11 | GND | ||
CN7-P12 | NC | ||
CN7-P13 | CSI2-D2N | ||
CN7-P14 | CSI-RST-R | PE16 | |
CN7-P15 | CSI2-D2P | ||
CN7-P16 | CSI-STBY-R | PE17 | |
CN7-P17 | GND | ||
CN7-P18 | CSI-PCLK | PE0 | |
CN7-P19 | CSI2-CKN | ||
CN7-P20 | CSI-MCLK | PE1 | |
CN7-P21 | CSI2-CKP | ||
CN7-P22 | CSI-HSYNC | PE2 | |
CN7-P23 | GND | ||
CN7-P24 | CSI-VSYNC | PE3 | |
CN7-P25 | CSI2-D1N | ||
CN7-P26 | CSI-D9 | PE13 | |
CN7-P27 | CSI2-D1P | ||
CN7-P28 | CSI-D8 | PE12 | |
CN7-P29 | GND | ||
CN7-P30 | CSI-D7 | PE11 | |
CN7-P31 | CSI2-D0N | ||
CN7-P32 | CSI-D6 | PE10 | |
CN7-P33 | CSI2-D0P | ||
CN7-P34 | CSI-D5 | PE9 | |
CN7-P35 | GND | ||
CN7-P36 | CSI-D4 | PE8 | |
CN7-P37 | CSI-SCK | PE14 | |
CN7-P38 | CSI-D3 | PE7 | |
CN7-P39 | CSI-SDA | PE15 | |
CN7-P40 | CSI-D2 | PE6 |
Display specification
MIPI DSI PIN define of Banana pi BPI-M3 | |||
CN6-P01 | VCC-MIPI | ||
CN6-P02 | IPSOUT | ||
CN6-P03 | VCC-MIPI | ||
CN6-P04 | IPSOUT | ||
CN6-P05 | GND | ||
CN6-P06 | IPSOUT | ||
CN6-P07 | GND | ||
CN6-P08 | IPSOUT | ||
CN6-P09 | NC | ||
CN6-P10 | GND | ||
CN6-P11 | NC | ||
CN6-P12 | DSI-D0N | ||
CN6-P13 | NC | ||
CN6-P14 | DSI-D0P | ||
CN6-P15 | NC | ||
CN6-P16 | GND | ||
CN6-P17 | TWI0-SDA | PH1-EINT1 | |
CN6-P18 | DSI-D1N | ||
CN6-P19 | TWI0-SCK | PH0-EINT0 | |
CN6-P20 | DSI-D1P | ||
CN6-P21 | TP-INT | PL7-S-EINT7 | |
CN6-P22 | GND | ||
CN6-P23 | TP-RST | PL6-S-EINT6 | |
CN6-P24 | DSI-CKN | ||
CN6-P25 | GND | ||
CN6-P26 | DSI-CKP | ||
CN6-P27 | LCD-BL-EN | PD29 | |
CN6-P28 | GND | ||
CN6-P29 | LCD-RST | PD26 | |
CN6-P30 | DSI-D2N | ||
CN6-P31 | LCD-PWR-EN | PD27 | |
CN6-P32 | DSI-D2P | ||
CN6-P33 | GND | ||
CN6-P34 | GND | ||
CN6-P35 | LCD-PWM | PD28 | |
CN6-P36 | DSI-D3N | ||
CN6-P37 | GND | ||
CN6-P38 | DSI-D3P | ||
CN6-P39 | AP-RESET# | ||
CN6-P40 | GND |
Uart debug pin of Banana pi BPI-M3 | |||
CON2 P03 | UART0-TXD | PB9 | |
CON2 P02 | UART0-RXD | PB10 | |
CON2 P01 | GND |
- How to burn android image to eMMC under windows : https://bananapi.gitbooks.io/bpi-m3/content/en/how_to_burn_android_image_to_emmc.html
- BPI-M3 How to control GPIO on Android :https://bananapi.gitbooks.io/bpi-m3/content/en/howtocontrolgpioonandroid.html
- How to burn Linux image to eMMC : https://bananapi.gitbooks.io/bpi-m3/content/en/howtoburnlinuximagetoemmc.html
- GPU for kernel 3.4 : https://bananapi.gitbooks.io/bpi-m3/content/en/gpuforkernel34.html
- How to rotate display screen : https://bananapi.gitbooks.io/bpi-m3/content/en/howtorotatedisplayscreen.html
- how to use fatload uEnv.txt & script.bin & kernel uImage : https://bananapi.gitbooks.io/bpi-m3/content/en/howtousefatloaduenvtxtscriptbinkernel_ui.html
Opnewrt
TinaLinux
- How to setup docker env. to build github source code
- How to compile BPI-M3-bsp kernel on BPI-M3
- BPI-M3 BSP Cross Compile teach
- BPI-M3 fix rootmydevice issue for Security Alert
- BPI-M3 android 5.1 source code : https://drive.google.com/open?id=0B\_YnvHgh2rwjaGhIeUE0eERTZU0
- BPI-M3 Linux BSP code : https://github.com/BPI-SINOVOIP/BPI-M3-bsp
- BPI-M3 schematic diagram :google driver
- BPI-M3 DXF file : https://drive.google.com/file/d/0B4PAo2nW2KfnNm54VjBlUXhXekU/view
- BPI-M3 3D design file : https://drive.google.com/file/d/0B4PAo2nW2KfnYXVGWXBURDFSeTA/view
- A83T chip Datasheet V1.4 : https://drive.google.com/file/d/0B4PAo2nW2KfnM2VqeTR3SXpGdVE/view?usp=sharing
- Allwinner A83T chip User_Manual V1.5.1 : https://drive.google.com/file/d/0B4PAo2nW2KfnRjlQaU9uR0J0elE/view?usp=sharing
- android 5.0 development document(chinese):https://drive.google.com/file/d/0B4PAo2nW2KfnekpvMnlNZ2p6NWs/view?usp=sharing
- allwinner chip online datasheet and documents : http://dl.linux-sunxi.org/
- linux-sunxi wiki : http://linux-sunxi.org/Banana_Pi_M3
- BPI-M3 quality guarantee
- BPI-M3 WIFI Lab test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3wifilabtest.html
- BPI-M3 Validation test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3validationtest.html
- BPI-M3 CE,FCC RoHS Certification : http://forum.banana-pi.org/t/bpi-m3-ce-fcc-rohs-certification/984
Android 5.1.1 V5
- 2018-06-05 update
- HDMI-Version
- Google Drive : https://drive.google.com/open?id=1mLXOAH_LPT-uqtwWvgvJXw4Vo95tFr_z
- Baidu Cloud : https://pan.baidu.com/s/1byqwqzz9SOIWHYfOabXKNw
- LCD-Version
- Google Drive : https://drive.google.com/open?id=1DAxQIws0eAVPAm0riH5HXc8M36SH_-sC
- Baidu Cloud : https://pan.baidu.com/s/19l7a6Z75FuZb_f9Ls0fN5w
- 2017-05-11 update
- HDMI-Version
- Google Drive : https://drive.google.com/open?id=0B_YnvHgh2rwjcXkxczlmOWxWV00
- Baidu Cloud : https://pan.baidu.com/s/1pKF3Ggj
- MD5: d7b7abf3443a49fb0f178ccf2f6e82d0
- LCD-Version
- Google Drive : https://drive.google.com/open?id=0B_YnvHgh2rwjSkM5NHFWYVdlakk
- Baidu Cloud : https://pan.baidu.com/s/1mi2YOeG
- MD5: b27dd45ac5fd1fd3b02db8ffd92c2871
- forum pthread : http://forum.banana-pi.org/t/bpi-m3-new-image-android-5-1-version-v5-2017-05-11/3241
- 2022-09-07 Armbian_22.11.0-trunk_Bananapim3_jammy_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1iq0gCOAIHjE7bgxeccNPtFp9iK0AtzRM/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1FjNBqpJ0Kv83EpiKt9sZmw?pwd=mtk5 (pincode: mtk5)
- 2021-08-03 release, Ubuntu Mate Desktop 16.04 with kernel 3.4.39
- Download: 2021-08-03-ubuntu-16.04-mate-desktop-bpi-m3-sd-emmc.img.zip
- MD5: 4cd6cfb9ed3a2d382dbc32bb478ac149
- 2021-08-03 release, Ubuntu Server 16.04 with kernel 3.4.39
- Download: 2021-08-03-ubuntu-16.04-server-bpi-m3-sd-emmc.img.zip
- MD5: ea5abe3fd6988931df85a2376808501a
- 2018-07-18 BPI-M3 Ubuntu 16.04 Mate Desktop (new eMMC)
- Features Map :http://wiki.banana-pi.org/M3_Image_Map#Ubuntu_16.04
- Google Drive : https://drive.google.com/open?id=1DlOrt08yUY9hAETiUXBiyoyPFHrOxtvq
- Baidu Drive : https://pan.baidu.com/s/1ND5QqoBevzM2TykwqZCkAA
- forum pthread: http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-new-emmc-ubuntu16-04-debian9-release-2018-07-18/6294
- 2018-07-18 M3 Ubuntu Server (new eMMC)
- Features Map : http://wiki.banana-pi.org/M3_Image_Map#Ubuntu_Lite
- Google Drive : https://drive.google.com/open?id=1Yyd2BepHjyhgXhSmnFh_0Az6YoXPEI3J
- Baidu Drive : https://pan.baidu.com/s/10vSo0AmIiMrVLNPkQ63leQ
- 2018-05-31 update ubuntu 16.04 mate desktop
- HDMI verison baidu cloud : https://pan.baidu.com/s/1UDktbDgGtXpbqIZn_TI1Tg
- 2017-07-13 update ubuntu 16.04 mate desktop
- Image Link:
- HDMI version Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjRThoaHliWVVyZGM/view?usp=sharing
- HDMI verison baidu cloud : http://pan.baidu.com/s/1nu6hJs9
- Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-ubuntu-16-04-mate-desktop-beta-bpi-m3-ov8865-sd-emmc-2017-07-13/3542
- LCD 7 verison Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjVldzUENFQXpiTHc/view?usp=sharing
- LCD 7 version baidu cloud : http://pan.baidu.com/s/1o8Uc4Y2
- Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-ubuntu-16-04-mate-desktop-beta-bpi-m3-lcd7-ov8865-sd-emmc-img-2017-7-13/3543
- LCD 5 Version Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjUlpIVjB6LVVmMGc/view?usp=sharing
- LCD 5 Version baidu cloud : http://pan.baidu.com/s/1hsIJygG
- Forum thread:http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-ubuntu-16-04-mate-desktop-beta-bpi-m3-lcd5-ov8865-sd-emmc-img-2017-7-13/3544
- 2022-09-07 Armbian_22.11.0-trunk_Bananapim3_bullseye_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1vrM4WLq74O4FEOAmBjUwJGbzZptq3hYi/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1w00wkfX15G6D60W2WH52ug?pwd=awza (pincode: awza)
- 2018-07-18 BPI-M3 Debian Jessie 9 (new eMMC)
- Features Map : http://wiki.banana-pi.org/M3_Image_Map#Debian_Jessie_9
- Google Drive : https://drive.google.com/open?id=1M997Uf-RVqdFKJkXMjgY0w3fHyiOq4iG
- Baidu Drive : https://pan.baidu.com/s/1yQYG1iOEIrJADV_j-qvdwQ
- Forum pthread : http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-new-emmc-ubuntu16-04-debian9-release-2018-07-18/6294
- Armbian_23.02.0-trunk_Bananapim3_jammy_edge_6.1.11_xfce_desktop.img
- Armbian_23.02.0-trunk_Bananapim3_bullseye_edge_6.1.0_xfce_desktop.img
- Baidu Cloud: https://pan.baidu.com/s/1hkkl22uVjvRct1V7N4OK2w?pwd=8888
- Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
- Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m3-new-armbian-image/15138
- 2022-12-06 Armbian_22.11.0-trunk_Bananapim3_bullseye_edge_6.0.9.img.xz
- Google Drive:https://drive.google.com/file/d/1Cr0KY0oVqSly-DOipgd_x_a4gQ0oPxm7/view?usp=share_link
- Baidu Cloud:https://pan.baidu.com/s/18M5Tsc91z57NUzBm4rcqlg?pwd=8888 (pincode: 8888)
- Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-release-armbian-bullseye/14450
- Armbian with 4.17.y for M3
- Test build:http://ix.io/1fUK
- Broken: wired, wireless network, Bluetooth, ...
- Works: serial console, 8 cores, DVFS, USB, SATA, HDMI, DRM video driver, ...
- image:https://forum.armbian.com/topic/474-banana-pi-m3/?do=findComment&comment=57400
- Forum pthread:http://forum.banana-pi.org/t/armbian-with-4-17-y-for-m3/6174
Raspbian
- 2021-08-03 release, Raspbian Stretch with kernel 3.4.39
- Download: 2021-08-03-raspbian-stretch-bpi-m3-sd-emmc.img.zip
- MD5: a9890cedbd779a29ff551a7fc5e1eae6
- 2018-5-28 update : Raspbian 8.0 V1.1
- Image Link:
- Google Drive: https://drive.google.com/open?id=1DSZru8UQRikI6pImLZIt1DmySVozy0FA
- baidu cloud : https://pan.baidu.com/s/1Pz_6btHxj6F9w_6aw90Dww
- Forum thread:
- Image Link:
Arch Linux
- 2018-08-19 ArchLinux-4.18.1-1-ARCH : Kernel: 4.18.1-1-ARCH U-Boot: 2018.09-rc1
- U-Boot: 2018.09-rc1,Kernel: 4.18.1-1-ARCH,Ethernet works,Wifi works,HDMI works,LCD needs to be checked(I would appreciate if someone can check it),GPIO works(WiringPi),BPI tools included,I2C enabled(In TDB file)
- source code on github : https://github.com/apankevych/BananaPi-M3-Linux-4.18.1-1-ARCH
- download Image link:https://drive.google.com/file/d/1ia3JSmHH8ksia4e8doalUGSBHnytOgx4/view?usp=sharing
- Forum pthread : http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-archlinux-4-18-1-1-arch-2018-08-19/6544
- 2018-07-19 Arch Linux sunxi kernel-4.18-rc3 and uboot- 2018.01 thank Andriy_Pankevych do this great work.
FreeBSD
Simplenas
- simplenas image : https://simplenas.com/download/other/banana-m3
Lakka TV
- Banana Pi M2+ with H3 chip
- Banana Pi M3 with A83T chip
Others image
- SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M3/1100417230_40000003593419.html?
- Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M3/1101951077_40000003551100.html?
- Taobao Shop: https://shop108780008.taobao.com/category-1694930638.htm?
