Getting Started with BPI-M6
Revision as of 18:31, 21 September 2023 by Squy (talk | contribs) (Prepare)
Banana Pi BPI-M6 with Synaptics VS680
1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download.
1. Download and install the SenarySocSystemTool for android image download via USB type-c on M6, only support windows.
1. Open SenarySocSystemTool.exe, click Browse, and select the eMMCimg folder where the image is located.
2. Press the USB button next to type-c and connect to the computer using the type-c cable.
3. Click to start burning, and then wait for the burning to complete.
4. After Burning successfull, press the RST key, Unplug the usb and connect to power supply adaptor to startup.
5. If you want to erase eMMC, you can repeat the above steps, but you need to click on Erase eMMC instead of starting the burn.
