Getting Started with BPI-R3 MINI
MediaTek MT7986(Filogic 830)
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE Ethernet port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface * Using your USB-Serial Connect debug console on BPI-R3 MINI Note: Debug Uart 3.3v TTL![]()
Warnning
if you want to update EMMC device, please boot from Nand
otherwise you update Nand device when it boot from EMMC.
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
2. Change boot switch Jumper, the board boot from Nand device, then power up the board.
4. Execute following command to enable and copy image to EMMC device:
* dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
5. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device.
1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk.
2. Change boot switch Jumper, the board boot from EMMC device, then power up the board.
* mtd erase /dev/mtd0
* dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
5. power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device.
Network-Configuration
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:6
root@OpenWrt:/#
FAN
- CN16 supports PWM control.
PWM FAN Control
M.2 KEY B slot
currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN
when you install one 4G/5G module, you may check it.
4G/5G Module
BPI-R3mini supports M.2 KEYB USB interface Cellular network module: 4G LTE EM05, 5G Quectel RM500U-CN/RG200U-CN and RM520N-GL/RM500Q-GL Series.
The released image(2023-09-12 or later) default driver is RM500U-CN and RM520N-GL, Install one of these two modules and you can use it directly.
If use EM05 or others,you will most likely need to modify the driver.
Wi-Fi Ap mode on BPI-R3mini
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Serial cable
Because the UART0_TXD of the debug port is also a wifi strap pin, this pin needs to be pull-low when poweron,
some serial cable have strong pull-up, such as PL2303,if it is inserted before powering on, it will cause the wifi chip to be recognized incorrectly, and the wifi function will fail.
Other types including cp2102,ch340 and FDTI are all available, serial cable vlotage must be 3.3v LVTTL standard.
You can buy the serial cable here: https://www.aliexpress.us/item/3256805457599756.html?
If your computer has a USB TypeC connector and supports PD12V/1.5A (20W) or above, you can also directly use the computer to power BPI-R3mini.
Moreover, since BPI-R3mini has built-in USB to serial port chip CH340E, you do not need to use additional serial cables.
NOTE:If your computer does not support USB PD, then the R3mini will most likely keep restarting.
Because the power consumption of R3mini is relatively large (all peripherals are plugged in and the power consumption is close to 20W when running)
TTL Voltage
