Banana Pi BPI-M2 Berry
Revision as of 01:15, 23 August 2023 by Sinovoip (talk | contribs)
Banana Pi BPI-M2 Berry with Allwinner A40i
File:Banana pi BPI-M2 Berry 4.jpg
Overview:front
File:Banana pi BPI-M2 Berry 3.JPG
Overview:back
BPI-M2 Berry for BPI 4.0 Successful case :R40 for vehicle license plate recognition
BPI-M2 Berry for BPI 4.0 Successful case :R40 for IoT gateway with Z-wave, zigbee,WiFI
BPI-M2 Berry case
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner A40i SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and last but not least, a SATA port..
  • Allwinner A40i/R40/V40 Quad Core ARM Cortex A7 CPU
  • 1GB DDR3 SDRAM.
  • WiFi & BT onboard
  • SATA Interface
  • 4*USB 2.0
  • MIPI DSI interface
  • CSI camera interface
HardWare Specification of Banana pi BPI-M2 Berry
Soc Allwinner A40i/R40/V40
SDRAM 1GB DDR3 with 733MHz\(shared with GPU\)
SATA suppoort SATA interface
Bluetooth BT4.0
On board Storage MicroSD \(TF\) card,No eMMC onboard
USB 4 USB 2.0 host, 1 USB 2.0 OTG
IR No onboard IR receiver
battery No 3.7V lithium battery power support
Weight 40g
CON1-P02 DCIN
CON1-P03 TWI2-SDA PB21 PWM5
CON1-P04 DCIN
CON1-P05 TWI2-SCK PB20 PWM4
CON1-P07 PB3 PB3 PWM1
CON1-P11 UART7-TX PI20
CON1-P13 UART7-RX PI21 PWM3
CON1-P15 PH25 PH25 CSI1-FIELD
CON1-P18 PH26 PH26 CSI1-HSYNC
CON1-P19 SPI0\_MOSI PC0
CON1-P21 SPI0\_MISO PC1
CON1-P22 PH27 PH27 CSI1-VSYNC
CON1-P23 SPI0\_CLK PC2
CON1-P24 SPI0\_CS PC23
CON1-P26 PH24 PH24 CSI1-PCLK
CON1-P27 TWI3-SDA PI1
CON1-P28 TWI3-SCK PI0
CON1-P29 PH0 PH0 CSI1-D0
CON1-P31 PH1 PH1 CSI1-D1
CON1-P32 PD20 PD20 CSI1-MCLK
CON1-P33 PH2 PH2 CSI1-D2
CON1-P35 PH3 PH3 CSI1-D3
CON1-P36 UART5-RX PH7 CSI1-D7
CON1-P37 UART4-TX PH4 CSI1-D4
CON1-P38 UART5-TX PH6 CSI1-D6
ON1-P39 GND
CON1-P40 UART4-RX PH5 CSI1-D5
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PI3
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PI2
CN5-P06 CSI0-Reset PI7
CN5-P07 CSI0-VSYNC PE3
CN5-P08 CSI0-PWDN PI6
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
Display specification
CN6-P01 VCC-3V3
CN6-P02 IPSOUT
CN6-P03 VCC-3V3
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PB19
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PB18
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PI10
CN6-P22 GND
CN6-P23 CTP-RST PI11
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PH16
CN6-P28 GND
CN6-P29 LCD-RST PH17
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PH18
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PB2
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
CON2 P03 UART0-TXD
CON2 P02 UART0-RXD
CON2 P01 GND
TinaLinux
Allwinner V40 datasheet
Allwinner R40 datasheet
axp221s PMU datasheet
  • Banana pi BPI-M2 Berry CE,FCC,RoHS
CE FCC RoHS
Android 6.0
  • 2017-08-25 update
  • HDMI-Version,LCD5-Version LCD7-Version,please choose which you are need:
google Drive : https://drive.google.com/drive/folders/0B_YnvHgh2rwjNFRpVFlhcW56LUk?resourcekey=0-95UrcQ-bb0Bh-RDtLRp-0w
  • 2022-04-16 Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10
  • 2020-04-19 update, kernel 3.10.108
Ubuntu 16.04 mate desktop Download
Ubuntu 16.04 server Download
  • 2019-05-13 update banana pi M2U board which is based on A40I, R40, V40, and it is based on Ubuntu 16.04 & Raspbian 9 & Debian 9 Operation system with kernel 3.10.108
BPI-M2U Ubuntu 16.04 Features Map:http://wiki.banana-pi.org/M2U/Berry_Image_Map#Ubuntu_16.04
Desktop images:
Google Drive :https://drive.google.com/file/d/1Q8MGksdugAsMhy4slj50Rp9P0eeDUQFo/view?usp=sharing
Baidu Drive : https://pan.baidu.com/s/1Aap1emViG6Vh2ejVHPtZhg?pwd=xfd5 (PinCode:xfd5)
MD5 : cde8fd1165b54c633bcc5288e8447c2b
Server images:
Google Drive : https://drive.google.com/open?id=1vcuIpQ7O2SFB3cZ4UemOqR2hQkxHy3RF
Baidu Drive : https://pan.baidu.com/s/18Cp7zeuHxa82z5OU_tV_oQ (PinCode:qat4)
MD5 : 07981887a7a21f5cda72ab8a1e37a834
Forum pthread : http://forum.banana-pi.org/t/bpi-m2u-berry-new-image-release-ubuntu-16-04-raspbian-9-4-debian-9-4-2019-05-13/9225
  • 2017-11-13 update
Debian 9 stretch mate desktop Download
Debian 9 stretch lite Download
BPI-M2U Debian 9 Features Map:http://wiki.banana-pi.org/M2U/Berry_Image_Map#Debian_9
Desktop images :
Google Drive :
Baidu Drive : https://pan.baidu.com/s/1ZqDZT4dOQNyvsu0nT4oMTg (PinCode:kshd)
MD5 : 7e5d848f804bc5ffb8854a93d7488694
Server images:
Google Drive : https://drive.google.com/open?id=1aoB8mGwSveNztB-EO_fBKLOr-GdzcMNV
Baidu Drive : https://pan.baidu.com/s/1V0djGvUR7QJFMeAgZV86zg (PinCode:e0t6)
MD5 : b7314d444dc13a40e1dd7b1602436f40
Raspbian
https://drive.google.com/drive/folders/0B_YnvHgh2rwjR0JsaUltalFXanc?resourcekey=0-sP6nS_7yziua5nmCfFQmAw&usp=share_link
BPI-M2U Raspbian 9 Features Map:http://wiki.banana-pi.org/M2U/Berry_Image_Map#Raspbian_9.4
Desktop image :
Google Drive : https://drive.google.com/file/d/146--P5XiX9F_Dn8JzC3gRApGBQUUcEzH/view?usp=sharing
Baidu Drive : https://pan.baidu.com/s/1ngowiaK1q20MbQMQzXabDw?pwd=8888 (PinCode:8888)
MD5 : f7ee24ff15654724e2c7ec3bf72c8506
  • 2023-07 BPI-M2 Berry Armbian_23.08.0 wiringpi
Google Drive:https://drive.google.com/file/d/1RaZcDPDp6a5otU8rrbGKhBKFVJ-As426/view?usp=drivesdk
Baidu Cloud:https://pan.baidu.com/s/1tOa_BymrKNXYTHciInmkXg?pwd=8888
Google Drive:https://drive.google.com/drive/folders/1DBvBi5RsPWYvgw7j2Gwq8JyOoDg-TXJw?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1qZqTYBfM2oK03RARcTEqng?pwd=8888 (pincode: 8888)
  • 2023-07 BPI-M2 Berry Armbian_23.05.0
Google Drive:https://drive.google.com/drive/folders/1mzcyy11sJyg0ZrDzdKj4JVjo9qrDjRyb?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1XYg5KjoAaxewIpv9NT-gcA?pwd=8888 (pincode: 8888)
  • Armbian_23.02.0-trunk_Bananapim2ultra_jammy_edge_6.1.11_xfce_desktop.img
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1hkkl22uVjvRct1V7N4OK2w?pwd=8888
Disucss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m2-berry-new-armbian-image/15140
  • 2022-12-06 Armbian_22.11.0-trunk_Banana Pi BPI-M2 Berry_bullseye_edge_6.0.9.img.xz
Google Drive:https://drive.google.com/file/d/1vyK13DB2Z1OMjGE9Wd1XHYIMFPZ8UuZI/view?usp=share_link
Baidu Cloud:https://pan.baidu.com/s/1GMUZGZcWWXPKRSW1X5fRKw?pwd=8888 (pincode: 8888)
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-berry-new-image-release-armbian-bullseye/14451
Boot logs : http://ix.io/1kVQ
Tina IoT Linux
more please see : Tina Linux
RPiTC v3 1.12
  • 2017-11-28 updtae
Others
