Banana Pi BPI-M4 Berry
BPI-M5 Introduction
The BPI-M4 Berry development board stands as a powerful Single Board Computer (SBC), harnessing the capabilities of the Allwinner H618 System-on-Chip (SoC) to provide developers with impressive performance and a wealth of features. Similar to the Raspberry Pi 4b, the BPI-M4 Berry boasts comparable CPU prowess, LPDDR4 memory support, integrated WiFi and Bluetooth functionalities, and a familiar 40-pin header layout, alongside 4 USB interfaces and a GbE RJ45 port.
It not only features a standard SD card slot for operating systems but also integrates a high-performance 8GB eMMC flash memory. This enhancement brings forth significantly accelerated system read and write speeds, expediting development and debugging processes, thereby furnishing a more stable and efficient foundation for project endeavors.
One of the flagship traits of the BPI-M4 Berry development board is its exceptional imaging and decoding capabilities. Equipped with a full-size HDMI 2.0a interface, it supports 4K resolution output at refresh rates of up to 60Hz. This empowers users with remarkable decoding capabilities, accommodating various video formats, including but not limited to, H.265 4K@60fps, 6K@30fps, VP9 4K@30fps, AVS2 4K@60fps, and H.264 4K@30fps. Furthermore, the BPI-M4 Berry also boasts H.264 4K@25fps encoding performance, rendering it an ideal choice for applications encompassing streaming, entertainment, and visual processing.
The BPI-M4 Berry's design flexibility makes it well-suited for diverse application scenarios within the hardware realm. Its Raspberry Pi-compatible 40-pin header facilitates seamless interfacing with a variety of sensors, expansion boards, and devices. Moreover, the availability of 4 USB interfaces facilitates connection to external peripherals, further extending its utility. The GbE RJ45 interface offers expedient high-speed network connectivity, 2.4G/5G WiFi and Bluetooth meet the communication needs of most mainstream wireless devices, positioning the BPI-M4 Berry as an optimal selection for networking applications and Internet of Things (IoT) projects.
The BPI-M4 Berry development board, characterized by its robust performance, versatile features, and remarkable image processing capabilities, stands as an exemplary SBC development platform for professionals within the embedded and computing industries. Equipped with 8GB eMMC flash storage, high-performance decoding and encoding capabilities, and an array of interface options, it caters to a wide spectrum of application domains, including media processing, IoT, and entertainment. Whether catering to novices or seasoned developers, the BPI-M4 Berry development board offers an ideal toolset for realizing creative visions and project objectives.
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
| CPU | Amlogic S905X3 64-bit Quad-Core Cortex-A55 (2.0xxGHz) | ||
| Memory | 4 GB LPDDR4 | ||
| Video Output(s) | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | ||
| Size & Weight | 85x56 mm, 48g | ||
| OS | Android and Linux | ||
| Network | 1 GbE ,WiFi&BT5.0 onbard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
BPI-M5 40PIN GPIO (CON2)
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | VCC5V | ||
| CON1-P04 | VCC5V | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P37 | GPIOAO_9 | I2S_MCLK | |
| CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
| CON2-P1 | GND |
| CON2-P2 | UART0-RX |
| CON2-P3 | UART0-TX |
