Banana Pi BPI-Wifi6 Router
BPI-Wifi6 Router Introduction
Banana Pi BPI-Wifi6 Router with Triductor TR6560 + TR5220 wifi SOC
Banana Pi BPI-Wifi6 Router Case design
  • Dual core ARM cortec A9 1.2G Hz
  • Integrated 5GE PHY, one RGMII
  • Supports 6 GE MACs,1000M/100M/10M rate mode and standard MIB statistics
  • Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
  • Support Wifi AP mode and STA mode
  • Support WPA,WPA2, WPA3 encryption and decryption, pay Chinese WAPI standard
  • PoE function support
Banana Pi BPI-Wifi6 Router specifications
BPI-Wifi6 Router Debug UART(J3)-TTL3.3V
PIN1 RXD
PIN2 NC
PIN3 3.3V
PIN4 GND
PIN5 TXD
PoE support
Easy to add PoE function suppport on BPI-Wifi6 router,The PoE module port is reserved on the board. If the PoE module is welded to the board, the PoE network cable power supply function is supported
  • Note : use BPI-RT5400-12V PoE module.
appearance design
we have design a case for BPI-Wifi6 Router board ,so you can use this board directly as a standard wifi6 router
this board support customized service. You can quickly produce your own wifi6 router products. And develop your own software on it
please refer to github bsp's pdf document: 创耀_TGP3.0开发手册_2023.4.20.pdf website: https://github.com/BPI-SINOVOIP/THG6500-TAX2-OPENWRT-BSP
  • Software Update
Baidu Cloud: https://pan.baidu.com/s/1uZ6Y4DSXhoPs83OE38bV6Q?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/file/d/1E5ArjrTuQAThgxh1xCD7LyqxHqh1eArV/view?usp=sharing
