Banana Pi BPI-CM2
Revision as of 08:19, 7 August 2023 by Sinovoip (talk | contribs)
BPI-CM2 Introduction
Banana Pi BPI-CM2 with RK3568 design
[[[Banana Pi BPI-CM4]] with A311D design
Banana Pi BPI-CM5 with A311D2 design
Banana Pi BPI-CM5 with BPI-CM4 base board
Banana Pi BPI-CM4 with A311D design
Banana Pi BPI-CM4 with base board
Banana Pi BPI-CM4 with Raspberry Pi CM4 base board
Banana Pi BPI-CM2 is a computer module with Rockchip RK3568 Quad-core ARM Cortex-A55 CPU, Mali-G52 1-Core-2EE GPU,2GB LPDDR4/LPDDR4x ,8 G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.\
Rockchip RK3568 provides a wealth of interface resources. In addition to the board-to-board connectors compatible with the Raspberry PI, other interfaces are also drawn from the board-to-board interface, so that you can design your own base board and use of the rich interface resources of the RK3568
Application direction
  • . Maker DIY
  • . Internet service gateway
  • . robot control
  • . Industrial control and industrial automation gateway
  • . Nas device
  • . Network and communication applications
  • 1. Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
  • 2. Mali-G52 1-Core-2EE GPU
  • 3. 2GB LPDDR4/LPDDR4x (Max 8G)
  • 4. 8G eMMC flash (Max 128G)
  • 14. support Android and Linux system.
  • 15. Size: 55x40mm
Getting Started with CM2
BPI-CM2 Module Hardware interface
BPI-CM2 Module PIN Out define
BPI-CM2 moudule base board interface
Banana Pi BPI-CM2 SBC specifications
Same size as RPI CM4
Third part image
