Banana Pi BPI-M2 Pro
BPI-M2 Pro Introduction
- Mali-G31 GPU
- 2GB LPDDR4
- 16GB eMMC flash
- 2 USB 3.0
- 1 GbE ethernet
- HDMI output
HardWare Specification of Banana pi BPI-M2 Pro | |||
CPU | Amlogic S905X3 64-bit Quad-Core Cortex-A55 (2.0xxGHz) | ||
Memory | 2 GB LPDDR4 | ||
Power Source | 5 volt @3A / 5 volt @2A via DC port | ||
OS | Android and Linux |
Network | 1 GbE ,WiFi&BT4.2 onboard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
BPI-M2 Pro 40PIN GPIO (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P39 | GND | ||
BPI-M2 Pro Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
- Same as BPI-M5 source code.
- BPI-M2 Pro PCB DXF file
- Amlogic S905x3 datasheet
- same to BPI-M5 images.
- 2023-03-01 release, tablet variant image
- 2023-03-01 release, box variant image
- 2023-03-01 release, Ubuntu Mate Desktop 20.04 with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/1aFY5XEN-dsEESX39-Bxa5g?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1yJSBk6AOJaRoF01-pqoVhB3eqqxqKEIL?usp=share_link
- 2023-03-01 release, Ubuntu Server 20.04 with kernel 4.9
- Baidu Cloud:https://pan.baidu.com/s/1eiPnqFUdbxa7_kfHrJP4gw?pwd=888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1gEbIXcaUzGQa0MPB1NwfnWlYJnFW-NbP?usp=share_link
- 2023-03-01 release, Debian 10 Buster lite with Kernel 4.9
- Baidu Cloud:https://pan.baidu.com/s/1pEdZUVE70IzZJamdam_W3g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/159Xyb7gWFlTnDAnnBL-jGn_p8s6ECFw2?usp=share_link
- 2023-03-01 release, Debian 10 Buster XFCE Desktop with Kernel 4.9
- Baidu Cloud:https://pan.baidu.com/s/1Ys6c64JRnO1CLpgNhHE-tg?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1JNbMay5W257bPBX7PBjzab6ISAmBe5XD?usp=share_link
Third part image
Raspbian
- BPI-M5 BPI-M2 Pro new image:Rasbian image, 2023-07-20 update,please choose the right image
- google driver: https://drive.google.com/drive/folders/1Rvr1l3LhnVcss0FD0_bAm3Jbi84vZBkT
- discuss on forum : https://pan.baidu.com/s/1T2DT3ruTRvRdFgIUrR1obg?pwd=8888 提取码:8888
- Image From Armbian Official website
- Image from Banana Pi team Released on 2023-07, Armbian_23.08.0
- Baidu Cloud: https://pan.baidu.com/s/13awWxoAeV7HuE0-2BViTIA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/drive/folders/1g585lGESqTVEenAPFDC-fAswXPilMIfD?usp=sharing
- Image From Banana Pi team Released on 2023-03-13, build from Armbian main branch source code, fix some bugs and support i2c, uart, spi and rtl8822cs overlays, you can enable the overlay in /boot/armbianEnv.txt
CoreELEC
- CoreELEC 19.2
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
HuaWei OpenEuler
- Download:
Manjaro for BPI-M5
CoreELEC on BPI-M2 Pro
easy to buy sample : https://pt.aliexpress.com/item/1005002661831086.html?spm=a2g0o.store_pc_allProduct.8148356.1.4fd039a06wVleh
