Getting Started with BPI-R3 MINI
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7976 and 5G wifi use MT7976, support 2 2.5GbE network port.
- MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE network port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface * Using your USB-Serial Connect debug console on BPI-R3 MINI
* R3 bootstrap and device select Jumper Setting![]()
Note: SW1-A and SW1-B is for boot strap selecting; SW1-C is that SPI-Nand or SPI-Nor Device is connected to CPU's SPI bus; SW1-D is that SD Card or EMMC device is connected tp CPU's EMMC bus. * Examples: All Jumper is High.![]()
All Jumper is Low.![]()
How to burn image to SD card
A. Note: burn image to SD card on linux computer 1.You could download latest image from our forum * Here is the example image link: 2.Install bpi-tools on your Ubuntu. If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually. * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card 4.After step 3, then you can insert your TF card into R3, and press power button to setup R3 B. Note: burn image to SD card on windows computer 1. Download the tools from the website: https://sourceforge.net/projects/win32diskimager/ 2. Install the tools into Windows computer. 3. flash image into SD card. C. Change Boot Jumper to boot from SD, Enable SD Card Device.![]()
Note: because SD card and EMMC device share one SOC's interface, you need flash one SD image firstly, then R3 boot from SD card, then flash nand image into Nand, then change boot strap to boot from nand, you need flash EMMC image into EMMC. Finally you change bootstrap to boot from EMMC.
4. Execute following command to enable and copy image to nand flash: * mtd erase /dev/mtd0 * dd if=mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bin of=/dev/mtdblock0
5. Shutdown, remove SD card, and change bootstrap to boot from nand flash and change SD/EMMC switch jumper to EMMC, restart the board from Nand Flash. Note: Enable EMMC device, boot strap is from nand![]()
6. repeat step 3, mount u-disk to /mnt, Execute following command to enable and copy image to EMMC device: * mount -t vfat /dev/sda1 /mnt * echo 0 > /sys/block/mmcblk0boot0/force_ro * dd if=bl2_emmc.img of=/dev/mmcblk0boot0 * dd if=mtk-bpi-r3-EMMC-WAN1-SFP1-20220619-single-image.img of=/dev/mmcblk0 * mmc bootpart enable 1 1 /dev/mmcblk0
7. power off R3 board, remove u-disk driver, change bootstrap to boot from emmc device. Note: Enable EMMC device, boot strap is from EMMC.![]()
Network-Configuration
- Network Interface: eth1, lan0 is for WAN; lan4, rax0, lan2, lan5, ra0, lan3, lan1 is for LAN, ra0 is for 2.4G wireless, rax0 is for 5G wireless.
root@OpenWrt:/# ifconfig
lo Link encap:Local Loopback
root@OpenWrt:/#
GPIO
26 Pins Definition
FAN
- R317 for 5V FAN and R318 for 12V FAN.
- CN23 supports PWM control while CN22 does not support.
PWM FAN Control
miniPCIe slot
SFP
After high and low temperature test, the following modules are suppoted by BPI-R3:
4G&5G
- BPI-R3 supports 4G LTE EC25.
- If you want to use 5G on BPI-R3:
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Wifi & Serial cable
UART_TX0 is the Boot Strapping PIN and must be kept low during power-on.
TTL Voltage
