Banana Pi BPI-R3 Mini
Revision as of 04:36, 26 July 2023 by Sinovoip (talk | contribs) (OpenWRT)
Banana Pi BPI-R3 Metal case
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 2.5GbE network port.
Application direction
  • . Internet service Router
  • . Wireless Router
  • . Wireless Repeater
  • . Home security Gateway
  • . Home Automation
  • . Nas device
  • . Soft router
  • . Network and communication applications
  • MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
  • Wifi 6 2.4G/5G(MT7976C)
  • 2G DDR RAM
  • 8G eMMC flash
  • 128MB Nand flash
  • 2x 2.5GbE network port
  • 1x M.2 Key B USB inerface
  • 1x M.2 KEY M PCIe inerface
  • 1x USB2.0 interface
HardWare Specification of Banana pi BPI-R3 Mini
CPU MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design
SDRAM 2 GB DDR4
On board Storage Nand flash,8GB eMMC onboard
On board Network 2 2.5GbE Ethernet
Wifi Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
1x M.2 Key B interface
M.2 Key M 1x M.2 KEY-M PCIe inerface
USB 1 USB 2.0
Buttons Reset button,WPS botton, boot switch
5 Leds Power ,System, Wifi 2G ,Wifi 5G ,4G Lte ,SSD
DC Power 20W/12V TypeC PD
Sizes
Weight 100g
SSD and 5G support
  • Opensource Driver BSP
https://github.com/BPI-SINOVOIP/BPI-R3MINI-OPENWRT-V21.02.3
Release image
  • 2023-07-19 BPI-R3 Mini OpenWRT image with Opensource Driver BSP
Google Drive:https://drive.google.com/drive/folders/1Lf04fV3MW7XWssxHLLUlOaZmJh_lRLY5?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1dsDxsNPttjbqg-qr7bHNWA?pwd=8888 (pincode:8888)
  • 2023-07-19 BPI-R3 Mini OpenWRT image with MTK vendor driver, Not OpenSource Driver BSP
Google Drive:https://drive.google.com/drive/folders/1KC0GAiTLUc_TK2g4rUD2AWgN4DXKNn2x?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/17h7Ts80noZqwDUYYaVPFIQ?pwd=8888 (pincode:8888)
Accessories
