Banana Pi BPI-Wifi6 Router
Revision as of 18:51, 19 June 2023 by Sinovoip (talk | contribs) (System image)
BPI-Wifi6 Router Introduction
Banana Pi BPI-Wifi6 Router with Triductor TR6560 + TR5220 wifi SOC
  • Dual core ARM cortec A9 1.2G Hz
  • Integrated 5GE PHY, one RGMII
  • Supports 6 GE MACs,1000M/100M/10M rate mode and standard MIB statistics
  • Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
  • Support Wifi AP mode and STA mode
  • Support WPA,WPA2, WPA3 encryption and decryption, pay Chinese WAPI standard
  • PoE function support
Banana Pi BPI-Wifi6 Router specifications
BPI-Wifi6 Router Debug UART(J3)-TTL3.3V
PIN1 RXD
PIN2 NC
PIN3 3.3V
PIN4 GND
PIN5 TXD
PoE support
Easy to add PoE function suppport on BPI-Wifi6 router,The PoE module port is reserved on the board. If the PoE module is welded to the board, the PoE network cable power supply function is supported
  • Note : use BPI-RT5400-12V PoE module.
  • will update soon
  • Update Software
Baidu Cloud: https://pan.baidu.com/s/1uZ6Y4DSXhoPs83OE38bV6Q?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/file/d/1E5ArjrTuQAThgxh1xCD7LyqxHqh1eArV/view?usp=sharing
