Banana Pi BPI-Wifi6 Router
Revision as of 18:10, 5 June 2023 by Sinovoip (talk | contribs) (BPI-Wifi6 Router Introduction)
  • Dual core ARM cortec A9 1.2G Hz
  • Integrated 5GE PHY, one RGMII
  • Supports 6 GE MACs,1000M/100M/10M rate mode and standard MIB statistics
  • Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
  • Support Wifi AP mode and STA mode
  • Support WPA,WPA2, WPA3 encryption and decryption, pay Chinese WAPI standard
Banana Pi BPI-Wifi6 Router specifications
