BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit PIN define
| HardWare Specification of Banana pi BPI-M2 zero | |||||
| P0 | ADC2_CH8 | DAC_1 | GPIO25 |
GPIO16
GPIO35
GPIO12
GPIO14
GPIO32
GPIO27
GPIO02
GPIO33
P14
P15
P16
3V3
P20
GND
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | SPI SPEED | 40NHz | |
| 2 | SPI MODE | DIO | |
| 3 | FLASH SIZE | 32Mbit | |
| 4 | COM | COMx(Fill in the port number assigned by the computer) | |
| 5 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
