Banana Pi BPI-M2 Pro
Revision as of 01:25, 12 April 2023 by Dangku (talk | contribs) (→Debian)
BPI-M2 Pro Introduction
  • Amlogic S905X3 64-bit Quad core Cortex-A55 (2.0xxGHz)
  • Mali-G31 GPU
  • 2GB LPDDR4
  • 16GB eMMC flash
  • 2 USB 3.0
  • RTL8821CU WiFi&BT 4.2 onboard
  • 1 GbE ethernet
  • HDMI output
HardWare Specification of Banana pi BPI-M2 Pro
CPU Amlogic S905X3 64-bit Quad-Core Cortex-A55 (2.0xxGHz)
Memory 2 GB LPDDR4
Wifi&BT Dual-band 802.11 b/g/n/ac WiFi 5 1×1 and Bluetooth 4.2 via Realtek RTL8821CU
USB ports 2x USB 3.0 host ports, 1x micro USB OTG port
Power Source 5 volt @3A / 5 volt @2A via DC port
Size & Weight 65mm×65mm, 58g
OS Android and Linux
Network 1 GbE ,WiFi&BT4.2 onboard GbE ,Optional WiFi USB dongle GbE GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
IR Yes Yes Yes N/A
BPI-M2 Pro 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M2 Pro Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Same as BPI-M5 source code.
same to BPI-M5 images.
Note: M2Pro is onboard 2GB ram, it's not work well for android, suggest to buy m5.
How to flash Android Image
  • 2023-03-01 release, tablet variant image
Baidu Cloud:https://pan.baidu.com/s/1cjzNgiE0-XJhvZgY0tQuHg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/144OU7NMTxLUqxNN2tXESgAoE3VXYgA_F?usp=share_link
  • 2023-03-01 release, box variant image
Baidu Cloud:https://pan.baidu.com/s/1SAfGM0WxOHW0vYCkjQUfbQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1Ipg8vZvKN_0xX0Fu24BW5UcDAHGhP7oH?usp=share_link
How to flash Linux Image
  • 2023-03-01 release, Ubuntu Mate Desktop 20.04 with Kernel 4.9
Baidu Cloud: https://pan.baidu.com/s/1aFY5XEN-dsEESX39-Bxa5g?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1yJSBk6AOJaRoF01-pqoVhB3eqqxqKEIL?usp=share_link
  • 2023-03-01 release, Ubuntu Server 20.04 with kernel 4.9
Baidu Cloud:https://pan.baidu.com/s/1eiPnqFUdbxa7_kfHrJP4gw?pwd=888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1gEbIXcaUzGQa0MPB1NwfnWlYJnFW-NbP?usp=share_link
  • 2023-03-01 release, Debian 10 Buster lite with Kernel 4.9
Baidu Cloud:https://pan.baidu.com/s/1pEdZUVE70IzZJamdam_W3g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/159Xyb7gWFlTnDAnnBL-jGn_p8s6ECFw2?usp=share_link
  • 2023-03-01 release, Debian 10 Buster XFCE Desktop with Kernel 4.9
Baidu Cloud:https://pan.baidu.com/s/1Ys6c64JRnO1CLpgNhHE-tg?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1JNbMay5W257bPBX7PBjzab6ISAmBe5XD?usp=share_link
Third part image
Raspbian
  • BPI-M5 BPI-M2 Pro new image:Rasbian image, 2022-4-09 update, Rasbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
google driver: https://drive.google.com/drive/folders/1oqamIMl5Kmb3LVYMPFw-1tilvwKQI6n-
  • Image From Armbian Official website
https://www.armbian.com/bananapi-m5/
  • Image From Bananapi Released on 2023-03-13, build from Armbian main branch source code, fix some bugs and support i2c, uart, spi and rtl8822cs overlays, you can enable the overlay in /boot/armbianEnv.txt
Baidu Cloud: https://pan.baidu.com/s/1Wgg_0Z7Db6DSKqoIjf16PQ?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1Yds8Rru_26S0wN2B-pIM6XkyxUXiceNl?usp=share_link
CoreELEC
  • CoreELEC 19.2
Volumio
Download:
Odroid Android image
Base on Odroid android source code and build for bananapi m5/m2pro
Download:
Ubuntu Core 20
Download:
Baidu cloud :
Archlinux
Download:
HuaWei OpenEuler
Download:
Manjaro for BPI-M5
CoreELEC on BPI-M2 Pro
easy to buy sample : https://pt.aliexpress.com/item/1005002661831086.html?spm=a2g0o.store_pc_allProduct.8148356.1.4fd039a06wVleh
