Getting Started with M2 Ultra & Berry
BPI-M2U
- 2GB DDR3 SDRAM
- 8 GB eMMC storage
- SATA Interface
BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Read more about : Banana Pi BPI-M2 Berry
- Quad Core ARM Cortex A7 CPU V40.
- 1GB DDR3 SDRAM.
- SATA Interface
* Prepare 8G/above TF card, USB-Serial interface, PC with Windows System * Using your USB-Serial Connect debug console on M2P 1.You could download the latest image from our wiki. * BPI-M2U: https://wiki.banana-pi.org/Banana_Pi_BPI-M2U#Image_Release * BPI-M2 Berry: https://wiki.banana-pi.org/Banana_Pi_BPI-M2_Berry 2.Put the TF card into a TF-USB adapter and plug it to your PC USB interface. 3.Download the flashing tools "BalenaEtcher" and start it. 4.Click "Flash from file" to select your image file.(.img or .zip) 5.Click "Select target" to choose your USB device. 6.Start to flash and wait for burning completely.![]()
Load your first image on M2U EMMC
1.Bootup your M2U with Micro SD card 2.Copy "xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to your USB disk 3.Plug your USB disk in M2U 4.Mount the USB disk and flash the image file to eMMC
* bpi-tools curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools%7Csudo -E bash mount /dev/sda1 /mnt cd /mnt bpi-copy xxx-sd-emmc-xxx.img.zip /dev/mmcblk0
* dd command mount /dev/sda1 /mnt cd /mnt unzip -p xxx-sd-emmc-xxx.img.zip |pv| dd of=/dev/mmcblk0 bs=10M status=noxfer
5.Then power off M2U, take TF card out, power on M2U
How to build uboot & kernel
Install tools
- apt-get udpate
- apt-get install pv
Clone code
- git clone: https://github.com/BPI-SINOVOIP/BPI-M2U-bsp.git
- ./build.sh
SATA
1. Mount SATA on M2U
- "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
LCD 5" & LCD 7"
- Find "BPI_M2U_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M2U console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2U
network={
ssid="ssid"
psk="password"
priority=1
We use HDF5640 camara.
IR function
- Execute "getevent"
- cd /usr/local/bin
WringPi
File System
Install Qt5.7 & Qtcreator
1.Prepare a 32Gb TF card
2.Use GParted to resize root point '/' as 32Gb
3.apt-get install libxcb*
4.download qt5.7
5.make & make install
6.apt-get install qtcreator
7.Config qtcreator
