Banana Pi BPI-M5
BPI-M5 Introduction
![](/images/thumb/4/4f/Banana_Pi_BPI-M5_4.JPG/300x225x300px-Banana_Pi_BPI-M5_4.JPG.pagespeed.ic.5eDUNHGM8e.jpg)
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
![](/images/thumb/6/6e/Banana_Pi_BPI-M2S_1.jpg/300x225x300px-Banana_Pi_BPI-M2S_1.jpg.pagespeed.ic.09oBHwAysc.jpg)
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
Memory | 4 GB LPDDR4 | ||
OS | Android and Linux |
SDIO interface Wifi&BT
- WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluetooth 5.0 , support BPI-M5 and BPI-F2P
- how to use : https://wiki.banana-pi.org/Getting_Started_with_M5/M2Pro#Wifi.2FBT_support
- RT8822CS Bluetooth and WiFi adapter for Banana Pi BPI-M5:https://www.magazinmehatronika.com/en/rt8822cs-bluetooth-and-wifi-adapter-for-banana-pi-m5/?fbclid=IwAR0Oqm4TCa2SAXBTMJgRmWMJI-VQREqFxLh1-LnT_XzA5MAvYh_BL9-L7Xk
BPI-M5 40PIN GPIO (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P37 | GPIOAO_9 | I2S_MCLK | |
CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
BPI-M5 runs wiringpi gpio
- BPI-M5/M2 PRO Android9 source code:
- Baidu Cloud: https://pan.baidu.com/s/1TmmR_075b49lPSt1Phq0ag?pwd=8888 (pincode: 8888)
- Google Drive:
Linux BSP source code
- BPI-M5 schematic diagram
- BPI-M5 PCB DXF file
- Amlogic S905x3 datasheet
- BANANA PI BPI-M5 REVIEW & BENCHMARKS:https://bret.dk/banana-pi-m5-review/
- BANANA PI M5 VS RASPBERRY PI 4 – BENCHMARKS : https://bret.dk/banana-pi-m5-vs-raspberry-pi-4/
- 2023-03-01-bpi-m5-m2pro-tablet-android9.img
- 2023-03-01-bpi-m5-m2pro-mbox-android9.img
- 2022-09-07 release, BPI-M2 PRO/M5-Mbox-Android9
- Baidu Cloud: https://pan.baidu.com/s/1vqFGBDzY0gdqIIkX8ap5GA?pwd=uex1 (pincode: uex1)
- Google Drive:https://drive.google.com/file/d/1qmVfN-ocQJ2WqTdFw3vk1f5_kDnRGZeM/view?usp=sharing
- MD5: ac9ac49c3b37b9cd85de65bd64f9552f
- 2022-09-07 release, BPI-M2 PRO/M5-Tablet-Android9
- Baidu Cloud: https://pan.baidu.com/s/1vrmPlyPttoKU-FkPZZE-Jg?pwd=ds7a (pincode: ds7a)
- Google Drive:https://drive.google.com/file/d/1m-b5wYWazMM_QgnQ5iQZiPRRD6AmF-Ao/view?usp=sharing
- MD5: 84d60f44761a4d4958a50e47eee7a62a
- 2023-03-01-ubuntu-20.04-mate-desktop-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/1aFY5XEN-dsEESX39-Bxa5g?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1yJSBk6AOJaRoF01-pqoVhB3eqqxqKEIL?usp=share_link
- 2023-03-01-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud:https://pan.baidu.com/s/1eiPnqFUdbxa7_kfHrJP4gw?pwd=888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1gEbIXcaUzGQa0MPB1NwfnWlYJnFW-NbP?usp=share_link
- 2022-09-06 release Ubuntu Mate Desktop 20.04 with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/1XE2K_KlVwP0hvjv_AChVgg?pwd=38vx (pincode: 38vx)
- Google drive: https://drive.google.com/file/d/1OGNaEylMR-VlfY6ynRkGQNuljLcvxoqe/view?usp=sharing
- MD5: 4b0528065ddcf634e9a43b6b7a6363b1
- 2022-09-06 release, Ubuntu server 20.04 with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/15g52JerxZejcwywH7zZOlg?pwd=jtv5 (pincode: jtv5)
- Google drive:https://drive.google.com/file/d/15Y80CDT07HfEgo2YVjTkLSeIUGk8GQUo/view?usp=sharing
- MD5: f377dc5246f9ed7133db95c9d34b5201
- 2023-03-01-debian-10-buster-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud:https://pan.baidu.com/s/1pEdZUVE70IzZJamdam_W3g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/159Xyb7gWFlTnDAnnBL-jGn_p8s6ECFw2?usp=share_link
- 2023-03-01-debian-10-buster-xfce-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud:https://pan.baidu.com/s/1Ys6c64JRnO1CLpgNhHE-tg?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1JNbMay5W257bPBX7PBjzab6ISAmBe5XD?usp=share_link
- 2022-09-06 release, Debian-10-buster with Kernel 4.9
- Baidu Cloud: https://pan.baidu.com/s/1BEdv5AWEYgkMcUX_ju4DPQ?pwd=2cw4 (pincode: 2cw4)
- Google Drive:https://drive.google.com/file/d/1IZ7IEFeb21ZnaAuknz9lr00jo95UX6ml/view?usp=sharing
- MD5: f6cbe3518e8a02267224a0aa0256ce11
Third part image
Raspbian
- BPI-M5 BPI-M2 Pro new image:Raspbian image, 2022-4-09 update, Raspbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
- Google driver: https://drive.google.com/drive/folders/1oqamIMl5Kmb3LVYMPFw-1tilvwKQI6n-
- discuss on forum : https://forum.banana-pi.org/t/bpi-m5-bpi-m2-pro-new-image-rasbian-image-2022-4-09-update/13246
- Image From Armbian Official website:
- Image From Bananapi Released on 2023-03, base on Armbian main branch source code, fix some bugs and support i2c, uart, spi and rtl8822cs overlays, you can enable the overlay in /boot/armbianEnv.txt
EmuELEC
- This is a porting of EmuELEC v4.5 for BPI-M5. I ported from odroid c4 official EmuELEC image. PS3 a XBOX ONE S gamepad controllers were tested and work fine.
- https://forum.banana-pi.org/t/emuelec-for-bpi-m5/12095
CoreELEC
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
HuaWei OpenEuler
- Download:
Manjaro for BPI-M5
