Banana Pi BPI-R3
Banana Pi BPI-R3 Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 + MT7531A chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 SFP 2.5GbE port, and 5 GbE network port.
Application direction
- . Internet service Router
- . Wireless Router
- . Wireless Repeater
- . Home security Gateway
- . Home Automation
- . Nas device
- . Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
- . 2G DDR RAM
- . 8G eMMC flash
- . 2 SFP 2.5GbE
- . 5 GbE network port
- . POE support (optional)
- . Mini PCIe via USB
- . M.2 KEY-E PCIe inerface
- . Mciro SD card interfact
- . 26 PIN GPIO
Jumper setting
Jumper Setting of Banana pi BPI-R3 | ||||
Jumper Setting | SW1 | SW2 | SW5 | SW6 |
SPIM-NoR | Low | Low | Low | X |
SPIM-Nand | High | Low | High | X |
eMMC | Low | High | High | Low |
SD card | High | High | X | High |
HardWare Specification of Banana pi BPI-R3 | |||
CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design | ||
SDRAM | 2 GB DDR4 | ||
GPIO | 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
On board Network | 5 Port 10/100/1000Mbps Ethernet | ||
SFP | 2 SFP 2.5GbE | ||
Wifi | Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) | ||
mini PCIE | Mini PCIe via USB | ||
M.2 interface | M.2 KEY-M PCIe inerface | ||
USB | 1 USB 3.0 host ,2 USB interface with slot. | ||
Buttons | Reset button,WPS botton, boot switch | ||
Sizes | 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2 | ||
Weight | 200g |
Official OpenWrt 21.02 for BPI-R3 repo:
- Frank’s U-Boot repo:
- Banana Pi BPI-R3 Review: Details, Pricing, & Features : https://androidpimp.com/embedded/banana-pi-bpi-r3-router-board/?fbclid=IwAR1G4cEco5iULwKG-C-n8MIiWOWZMhPborqmCzS2d3KIHx-eNQS-54lZnps
- Update OpenWrt to 22.03.3 SNAPSHOT:https://forum.banana-pi.org/t/bananapi-bpi-r3-update-openwrt-to-22-03-3-snapshot/14984
- 3D printed cases:https://forum.banana-pi.org/t/banana-bpi-r3-3d-printed-case/14246/43
- Cooling solutions topic: https://forum.banana-pi.org/t/bpi-r3-running-hot/14750
- Bananapi R3 review with WiFi / CPU benchmarks and power consumption numbers: https://wiki.junicast.de/en/junicast/review/bananapi-BPI-R3
Release image
- Latest official OpenWRT snapshot image:
- 2022-07-20
- Google Drive:https://drive.google.com/file/d/13nQMfM0_XTyWcILhNxv_9E4TIvb65RI0/view?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/1-5tqHEacMw1wlTSEK1ey9A?pwd=8888 (pincode: 8888)
Frank’s image
- Frank’s Debian Bullseye image:
- Frank’s Ubuntu 22.04 image:
Failed to save the configuration
- Enter "mtd erase /dev/mtd10"
