香蕉派 BPI-M1+
Revision as of 22:05, 15 March 2023 by Sinovoip (talk | contribs) (介绍)
BPI-M1+ 3D
BPI-M1/M1+ for BPI 4.0 Successful case :3G Information security terminal
BPI-M1/M1+ for BPI 4.0 Successful case :4G Industrial safety tablets
Banana Pi BPI-M1+是一款开源硬件单板电脑,为BPI-M1经典版本增加了更多的连接性。
Banana PI BPI-M1+是一款高性能双核开源硬件单板计算机,Banana PI BPI-M1+是一款比树莓派 2B 更强悍的双核Android4.4与Linux产品。
Banana PI BPI-M1+兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统
Banana PI BPI-M1+硬件:1Ghz ARM7双核处理器,1GB DDR3内存,千兆以太网口,板载SDIO接口的WIFI模块SATA Socket,流畅运行Android4.4。Banana PI BPI-M1+体积如信用卡大小,轻松运行《雷神之锤三:竞技场》这样的游戏,支持1080P高清视频输出,GPIO兼容Raspberry Pi 2并直接运行其ROM Image。
  • 1 GB DDR3 memory.
  • Wifi &BT support onboard
  • 1x SATA interface.
  • 1x Gigabit LAN
  • 1x USB otg and 2x USB 2.0
  • 1X MIC
  • AV out
  • HDMI out
  • IR
  • CSI camera interface
  • DSI display interface
  • 40 PIN gpio
  • 3.7V lithium battery interface
开始使用
硬件接口示意
Banana Pi BPI-M1+ 硬件规格
Memory 1GB DDR3
Network 10/100/1000 Ethernet
wifi&BT Wifi & BT 4.0 support onboard
Power Source 5V/2A via Micro USB (DC in only) and / or Micro USB OTG
LED Power Key & 8P8C
Storage SATA 2.0
GPIO PIN 定义
40 PIN GPIO of Banana pi BPI-M1+
GPIO Pin Name Default Function Function2:GPIO
CON3-P01 VCC-3V3
CON3-P02 VCC-DC
CON3-P03 TWI2-SDA PB21
CON3-P04 VCC-DC
CON3-P05 TWI2-SCK PB20
CON3-P06 GND
CON3-P07 PWM1 PI3
CON3-P08 UART3\_TX PH0
CON3-P09 GND
CON3-P10 UART3\_RX PH1
CON3-P11 UART2\_RX PI19
CON3-P12 PH2 PH2
CON3-P13 UART2\_TX PI18
CON3-P14 GND
CON3-P15 UART2\_CTS PI17
CON3-P16 CAN\_TX PH20
CON3-P17 VCC-3V3
CON3-P18 CAN\_RX PH21
CON3-P19 SPI0\_MOSI PI12
CON3-P20 GND
CON3-P21 SPI0\_MISO PI13
CON3-P22 UART2\_RTS PI16
CON3-P23 SPI0\_CLK PI11
CON3-P24 SPI0\_CS0 PI10
CON3-P25 GND
CON3-P26 SPI0\_CS1 PI14
CON3-P27 TWI3-SDA PI1
CON3-P28 TWI3-SCK PI0
CON3-P29 I2S\_MCLK PB5
CON3-P30 GND
CON3-P31 I2S\_BCLK PB6
CON3-P32 I2S\_DI PB12
CON3-P33 I2S\_LRCK PB7
CON3-P34 GND
CON3-P35 I2S\_DO0 PB8
CON3-P36 UART7\_RX PI21
CON3-P37 IR0\_TX PB3
CON3-P38 UART7\_TX PI20
CON3-P39 GND
CON3-P40 SPDIF\_DO PB13
CSI PIN of Banana pi BPI-M1+
CSI Pin Name Default Function Pin name Function2:GPIO
CON1 P01 LINEINL
CON1 P02 LINEINR
CON1 P03 VCC-CSI
CON1 P04 ADC\_X1
CON1 P05 GND
CON1 P06 ADC\_X2
CON1 P07 FMINL
CON1 P08 ADC\_Y1
CON1 P09 FMINR
CON1 P10 ADC\_Y2
CON1 P11 GND
CON1 P12 CSI-FLASH PH17
CON1 P13 LRADC0
CON1 P14 TWI1-SDA PB19
CON1 P15 LRADC1
CON1 P16 TWI1-SCK PB18
CON1 P17 CSI-D0 PE4
CON1 P18 CSI0-STBY-EN PH19
CON1 P19 CSI0-D1 PE5
CON1 P20 CSI-PCLK PE0
CON1 P21 CSI-D2 PE6
CON1 P22 CSI0-PWR-EN PH16
CON1 P23 CSI-D3 PE7
CON1 P24 CSI0-MCLK PE1
CON1 P25 CSI-D4 PE8
CON1 P26 CSI0-RESET\# PH14
CON1 P27 CSI-D5 PE9
CON1 P28 CSI-VSYNC PE3
CON1 P29 CSI-D6 PE10
CON1 P30 CSI-HSYNC PE2
CON1 P31 CSI-D7 PE11
CON1 P32 CSI1-STBY-EN PH18
CON1 P33 AP-RESET\#
CON1 P34 CSI1-RESET\# PH13
CON1 P35 CSI-IO0 PH11
CON1 P36 HPR
CON1 P37 HPL
CON1 P38 IPSOUT
CON1 P39 GND
CON1 P40 IPSOUT
LVDS PIN of Banana pi BPI-M1+
LVDS Pin Default Function Function2 Function3:GPIO
CON2 P01 IPSOUT\(5V output\)
CON2 P02 TWI3-SDA PI1
CON2 P03 IPSOUT\(5V output\)
CON2 P04 TWI3-SCK PI0
CON2 P05 GND
CON2 P06 LCD0-IO0 PH7
CON2 P07 LCDIO-03 PH12
CON2 P08 LCD0-IO1 PH8
CON2 P10 PWM0 PB2
CON2 P12 LCD0-IO2
CON2 P14 LCD0-DE PD25
CON2 P16 LCD0-VSYNC PD27
CON2 P18 LCD0-HSYNC PD26
CON2 P20 LCD0-CS
CON2 P22 LCD0-CLK PD24
CON2 P24 GND
CON2 P26 LCD0-D23 PD23
CON2 P28 LCD0-D22 PD22
CON2 P29 LCD0-D10 PD10
CON2 P30 LCD0-D21 PD21
CON2 P31 LCD0-D11 PD11
CON2 P32 LCD0-D20 PD20
CON2 P33 LCD0-D12 PD12
CON2 P34 LCD0-D19 PD19
CON2 P35 LCD0-D13 PD13
CON2 P36 LCD0-D18 PD18
CON2 P37 LCD0-D14 PD14
CON2 P38 LCD0-D17 PD17
CON2 P39 LCD0-D15 PD15
CON2 P40 LCD0-D16 PD16
UART debug PIN of Banana pi BPI-M1+
Pin Name Default Function GPIO
CON4 P03 UART0-TXD PB22
CON4 P02 UART0-RXD PB23
CON4 P01 GND
资源
软件源代码
参考文档
系统镜像
Android 4.4
  • 2018-07-28 update android 4.4 HDMI version image
Features Map:http://wiki.banana-pi.org/M1P_Image_Map
Baidu Drive:https://pan.baidu.com/s/1GYH8oDK3T_WcUFn-0t9YmQ
Google Drive:https://drive.google.com/open?id=13XTvWe90yvRdqNWiKCLZ0HcMgo33y2r6
Armbian image
Image lownload link :https://www.armbian.com/banana-pi-plus/
Debian Linux
google driver:https://drive.google.com/file/d/1FhbaO6pDBu5jSPYq1ghd7YKG-KvFy33Q/view?usp=sharing
forum pthread:http://forum.banana-pi.org/t/bpi-m1-m1-r1-new-image-debian-10-buster-mate-desktop-with-grub-support-boot-2019-07-kernel-5-1-1/9916
Officeal OpenWRT
BPI BSP for OpenWRT
FreeBSD
OpenSuse
OpenMediaVault
Arch Linux
Gentoo Linux
RaspBSD
CentOS
DietPi
FreeBSD/NetBSD
Lakka TV
Simplenas
