Banana Pi Single board computer Comparison
module |
BPI-M1 |
BPI-M1+ |
BPI-M2+ |
BPI-M2 Zero |
BPI-M2 Magic |
BPI-M2 Berry |
BPI-M2 Ulra |
BPI-M3 |
BPI-M64 |
photo |
CPU |
A20,32 Bit Cortex™-A7 Dual-Core |
H3,32 Bit Cortex™-A7 Quad-Core |
H2+,32 Bit Cortex™-A7 Quad-Core |
A33/R16,32 Bit Cortex™-A7 Quad-Core |
R40/V40,32 Bit Cortex™-A7 Quad-Core |
A83T,32 Bit Cortex™-A7 Octa-Core |
A64, 64 Bit Cortex A53 Quad Core |
GPU |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
PowerVR SGX544MP2 GPU |
ARM® Mali400MP2 |
Memory \(SDRAM\) |
1G (shared with GPU) |
512M(shared with GPU) |
512(shared with GPU) |
2G (shared with GPU) |
Onboard Storage |
SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot |
MicroSD(TF) card /MMC card slot eMMC 8GB(option) |
MicroSD (TF) card / MMC card slot eMMC 8GB SATA 2.0 port via USB |
MicroSD (TF) card / MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB |
Network |
10/100/1000 Ethernet |
NOPE |
NOPE |
Onboard WIFI &BT |
NOPE |
802.11b/g/n |
802.11b/g/n & BT4.0 |
Display |
HDMI, CVBS , LVDS/RGB |
HDMI |
mini HDMI |
MIPI/LVDS |
HDMI, MIPI |
HDMI, MIPI |
HDMI, MIPI |
HDMI, MIPI |
Camera |
Parallel 8-bit camera interface |
Parallel 8-bit camera interface MIPI Camera serial Interface(CSI) |
Video Outputs |
HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps |
HDMI 1.4 1080p@60fps Support H.265 decode by 4K@30fps, support H.264 video encoding up to 1080p@30fps |
HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps |
Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps |
HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps |
HDMI 1.4 HEVC/H.265 decoder(SW), Main profile, 1080p@30fps H.264 video encoding up to 1080p@60fps, 720p@120fps |
HDMI 1.4 Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,H.265 decode up to 4KP30 |
Audio Output |
3.5 mm Jack and HDMI |
HDMI |
mini HDMI |
4ohm/2.5W Speaker(2 Pin Hole) |
Audino In |
Microphone |
Microphone |
NOPE |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
GPIO |
26-PIN: GPIO, UART, I²C bus, SPI bus with two chip selects, CAN bus,PWM,+3.3 V, +5 V, ground |
40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. |
USB 2.0 Ports |
2 USB ports, 1 OTG microUSB port |
2 USB ports, 1 OTG microUSB por |
1 USB 2.0 OTG |
1 USB 2.0 ports, 1 OTG microUSB port |
4 USB ports, 1 OTG microUSB port |
Buttons |
Reset button, Power button, Uboot button |
LED |
Power LED (red), RJ45 LED (blue), user define LED (green) |
Power LED (red,Can be defined by user) |
Power led Status led |
User define LED (red/power, blue, green) |
