Banana Pi BPI-M5
Revision as of 03:23, 10 March 2023 by Dangku (talk | contribs) (Undo revision 13995 by Dangku (talk))
BPI-M5 Introduction
Amlogic S905X3 Processor
BPI-M5 case design
  • Mali-G31 GPU
  • 4GB LPDDR4
  • 16GB eMMC flash
  • 4 USB 3.0
  • 1 GbE ethernet
  • HDMI output
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 92x60mm, 48g
OS Android and Linux
SDIO interface Wifi&BT
  • WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluetooth 5.0 , support BPI-M5 and BPI-F2P
IR Yes Yes Yes N/A
BPI-M5 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_9 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M5 Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
BPI-M5 runs wiringpi gpio
  • BPI-M5/M2 PRO Android9 source code:
Baidu Cloud: https://pan.baidu.com/s/1TmmR_075b49lPSt1Phq0ag?pwd=8888 (pincode: 8888)
Google Drive:
Linux BSP source code
How to flash Android Image
  • 2023-03-01-bpi-m5-m2pro-tablet-android9.img
Baidu Cloud:https://pan.baidu.com/s/1cjzNgiE0-XJhvZgY0tQuHg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/144OU7NMTxLUqxNN2tXESgAoE3VXYgA_F?usp=share_link
  • 2023-03-01-bpi-m5-m2pro-mbox-android9.img
Baidu Cloud:https://pan.baidu.com/s/1SAfGM0WxOHW0vYCkjQUfbQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1Ipg8vZvKN_0xX0Fu24BW5UcDAHGhP7oH?usp=share_link
  • 2022-09-07 release, BPI-M2 PRO/M5-Mbox-Android9
Baidu Cloud: https://pan.baidu.com/s/1vqFGBDzY0gdqIIkX8ap5GA?pwd=uex1 (pincode: uex1)
Google Drive:https://drive.google.com/file/d/1qmVfN-ocQJ2WqTdFw3vk1f5_kDnRGZeM/view?usp=sharing
MD5: ac9ac49c3b37b9cd85de65bd64f9552f
  • 2022-09-07 release, BPI-M2 PRO/M5-Tablet-Android9
Baidu Cloud: https://pan.baidu.com/s/1vrmPlyPttoKU-FkPZZE-Jg?pwd=ds7a (pincode: ds7a)
Google Drive:https://drive.google.com/file/d/1m-b5wYWazMM_QgnQ5iQZiPRRD6AmF-Ao/view?usp=sharing
MD5: 84d60f44761a4d4958a50e47eee7a62a
How to flash Linux Image
Raspbian
  • BPI-M5 BPI-M2 Pro new image:Raspbian image, 2022-4-09 update, Raspbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
Google driver: https://drive.google.com/drive/folders/1oqamIMl5Kmb3LVYMPFw-1tilvwKQI6n-
  • 2023-03-01-ubuntu-20.04-mate-desktop-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1aFY5XEN-dsEESX39-Bxa5g?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1yJSBk6AOJaRoF01-pqoVhB3eqqxqKEIL?usp=share_link
  • 2023-03-01-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud:https://pan.baidu.com/s/1eiPnqFUdbxa7_kfHrJP4gw?pwd=888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1gEbIXcaUzGQa0MPB1NwfnWlYJnFW-NbP?usp=share_link
  • 2022-09-06 release Ubuntu Mate Desktop 20.04 with Kernel 4.9
Baidu Cloud: https://pan.baidu.com/s/1XE2K_KlVwP0hvjv_AChVgg?pwd=38vx (pincode: 38vx)
Google drive: https://drive.google.com/file/d/1OGNaEylMR-VlfY6ynRkGQNuljLcvxoqe/view?usp=sharing
MD5: 4b0528065ddcf634e9a43b6b7a6363b1
  • 2022-09-06 release, Ubuntu server 20.04 with Kernel 4.9
Baidu Cloud: https://pan.baidu.com/s/15g52JerxZejcwywH7zZOlg?pwd=jtv5 (pincode: jtv5)
Google drive:https://drive.google.com/file/d/15Y80CDT07HfEgo2YVjTkLSeIUGk8GQUo/view?usp=sharing
MD5: f377dc5246f9ed7133db95c9d34b5201
  • 2023-03-01-debian-10-buster-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud:https://pan.baidu.com/s/1pEdZUVE70IzZJamdam_W3g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/159Xyb7gWFlTnDAnnBL-jGn_p8s6ECFw2?usp=share_link
  • 2023-03-01-debian-10-buster-xfce-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud:https://pan.baidu.com/s/1Ys6c64JRnO1CLpgNhHE-tg?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1JNbMay5W257bPBX7PBjzab6ISAmBe5XD?usp=share_link
  • 2022-09-06 release, Debian-10-buster with Kernel 4.9
Baidu Cloud: https://pan.baidu.com/s/1BEdv5AWEYgkMcUX_ju4DPQ?pwd=2cw4 (pincode: 2cw4)
Google Drive:https://drive.google.com/file/d/1IZ7IEFeb21ZnaAuknz9lr00jo95UX6ml/view?usp=sharing
MD5: f6cbe3518e8a02267224a0aa0256ce11
Third part image
EmuELEC
CoreELEC
  • CoreELEC 19.2
Image From Armbian Official website:
https://www.armbian.com/bananapi-m5/
Google Drive: https://drive.google.com/drive/folders/1Cx_DA90Tbr8_M_8eQd-NwFUOp3UTwhYt
Baidu Cloud : https://pan.baidu.com/s/15y4LNg4K-w0vrwMTcg5VGQ Pincode: j9aj
Armbian Image Release on 2023-01-31
  • Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2.img
Baidu Cloud:https://pan.baidu.com/s/1Upd7P6rMnyEJCBZJIxSRaQ?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1u-7d07lTuodrEKZgYYA-QpJsBkOezB49?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2_minimal.img
Baidu Cloud: https://pan.baidu.com/s/1nuIxoexLcJseUZG7tgBPXw?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/142lKwhovq5l2vYChjSI5ZT_AK0Rj9rz7?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_gnome_desktop.img
Baidu Cloud:https://pan.baidu.com/s/1VLwACCGDcpMc3ypEG4AAOw?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/133RTp3FlSjxKRKzJllcVrAoxlaYd3wyg?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_cinnamon_desktop.img
Baidu Cloud:https://pan.baidu.com/s/1Z9H2uKtH_n0qSUSo5QnD6Q?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1GVk2D4h0vdHGUwibmSTYIYxj6WniNHhZ?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_jammy_current_6.1.2_minimal.img
Baidu Cloud:https://pan.baidu.com/s/1ggjlqRZoOdFaOcEOpBCJmw?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1hg7gkiRsWS0oMi01Sy9XoFVDwgTJRACt?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2_xfce_desktop.img
Baidu Cloud:https://pan.baidu.com/s/16AynRkvZZiuLq3Hjmi0BCg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1xu9vS6XZJ-IDKsLkSyeQGKP768ur2EXH?usp=share_link
  • Armbian_23.02.0-trunk_Bananapim5_bullseye_current_6.1.2.img
Baidu Cloud:https://pan.baidu.com/s/1y7qoQYKaK2DaX1VB87iweQ?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1rij80fqbaSPP79qYirWpf_4ivrW4wlDb?usp=share_link
Volumio
Download:
Odroid Android image
  • Base on Odroid android source code and build for bananapi m5/m2pro
Download:
  • Odroid ubuntu IMG for BPI-M5:
https://forum.banana-pi.org/t/odroid-ubuntu-img-for-bpi-m5/12169
Ubuntu Core 20
Download:
Baidu cloud :
Archlinux
Download:
HuaWei OpenEuler
Download:
Manjaro for BPI-M5
