Install Linux & Android images on Banana pi SBC
Revision as of 01:08, 7 March 2023 by Dangku (talk | contribs) (Install Android Images)
This page is main to describe how to install an image (Linux & Android) on Banana Pi SBC (TF card & Emmc) under Linux or Windows OS.
Install Images Under Windows PC
  • If you install images on TF card under windows pc, please format your TF card firstly, but doesn't need to format TF card under Linux pc
Fomat TF Card
Install Linux Images
Install Linux Images On TF Card
Use Win32DiskImager
Use balenaEtcher
Install Linux Images On Banana Pis' Emmc
  • Before install an linux image on board, please install an image on TF card firstly.
  • After you installed image on TF card, then power on board by TF card
  • Prepare image and store it in Udisk, plug Udisk into board.
  • Using "bpi-copy" or "dd" command to flash image on board Emmc.
Install Allwinner platform board Android Images
Install Android Images On TF Card
Use PhoenixCard
Install Android Images On Banana Pis' Emmc
Use PhoenixSuit
  • Connect board with PC by using usb-otg wire.
  • If PhoenixSuit can't recognise device, please install usb driver for windows pc
  • Open PhoenixSuit on windows, then press U-boot button on board when you connect PC with otg-usb wire.
Use PhoenixCard
Install Images Under Linux(Ubuntu) PC
