BPI-Centi-S3
BPI-Centi-S3 with ESP32-S3 back
BPI-PicoW-S3 with ESP32-S3
BPI-Leaf-S3 with ESP32-S3
BPI-Smart with ESP8266
BPI-Bit with ESP32
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
BPI-Centi-S3 is a small-sized ESP32-S3 development board with a 1.9-inch LCD onboard, suitable for the development of comprehensive Internet of Things application projects such as color display, interactive control, wireless communication, and sensor data acquisition.
Using the Espressif ESP32-S3 chip, it supports 2.4 GHz Wi-Fi and Bluetooth® Low Energy (Bluetooth® LE) dual-mode wireless communication.
In a compact space, it still provides an incremental rotary encoder, a buzzer, a WS2812 color LED, and all other available pins to meet diverse needs.
Support USB and external 3.7V lithium battery power supply, can realize automatic switching power supply function under dual power supply, and support USB charging mode, equipped with battery voltage detection circuit, convenient for power management.
  • ESP32-S3, Xtensa® 32 bit LX7
  • 2M PSRAM, 8M FLASH
  • 2.4G WIFI, Bluetooth 5, Bluetooth mesh
  • GPIO, PWM, I2C, SPI, RMT, I2S, UART, USB, JTAG
  • 1 * ST7789 LCD screen, 1.9-inch, 170*320 resolution, 8bit 8080 parallel port
  • 1 * Rotary Encoder
  • 1 * Buzzer
  • 1 * full color LED
  • 1 * JST SH 1mm 4-Pin I2C connector
  • 2 * JST SH 1mm 6-Pin
  • 1 * USB Type-C
  • 1 * MX 1.25mm 2-Pin battery connector, support charging
hardware
Schematic Diagram of Hardware Interface
Preparing...
Hardware Specifications
BPI-Centi-S3 Spec
SoC ESP32-S3, Xtensa® 32-bit LX7 dual-core processor
Clock Frequency 240MHz MAX
Internal ROM 384 KB
Internal SRAM 320 KB
Onboard FLASH ROM 8MB
On-chip PSRAM 2MB
WIFI IEEE 802.11 b/g/n, 2.4Ghz frequency band, 150Mbps
bluetooth Bluetooth 5, Bluetooth mesh
External crystal oscillator 40Mhz
RTC and Low­Power Management Power Management Unit (PMU) + Ultra-­Low-­Power Coprocessor(ULP)
GPIO 9 available GPIOs have been exported to the JST SH socket
Support Peripherals I2C, SPI, PWM, UART, RMT, I2S, SD
JST SH 1mm socket 1 x 4Pin, 2 x 6Pin
USB 1 x Full Speed USB 2.0 OTG, Type-C Female
USB Serial/JTAG Controller 1, USB full speed standard, CDC-ACM, JTAG
Screen size 1.9 inches
Screen resolution 170 x 320 RGB
Screen control chip ST7789V3
Screen interface 8bit 8080 parallel port
Incremental Rotary Encoder 1
Buzzer 1
Color LED 1 x WS2812 2020
Machine working temperature -20℃ ~ +60℃
Working voltage 3.3V
USB input voltage 3.3V~5.5V
Battery connector MX 1.25mm 2-Pin
USB charging Support
Maximum charging current 500mA
Hardware Dimensions
BPI-Centi-S3 Dimensions
Mounting hole spacing
Mounting hole size
Motherboard size 26 x 63(mm)/1.02 x 2.48(inches)
Espressif ESP-IDF
MicroPython
CircuitPython
Arduino
