Banana Pi BPI-P2 Pro
Banana Pi BPI-P2 Pro is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Arm Cortex-A35 Rockchip RK3308 processor, with 2G RAM memory.8G eMMC flash,100M LAN,add PoE function support ,Wifi & Bluetooth onboard, It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308.
  • 2G LPDDR2 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
How to development : Getting Start with BPI-P2 Pro
Memory \(SDRAM\) 2G 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
Audio Output Mic Mini HDMI Mini HDMI Mini HDMI
USB 2.0 Ports one USB 2.0 OTG one USB 2.0 OTG one USB 2.0 OTG one USB 2.0 OTG
IR N/A N/A N/A N/A
Weight 30g 30g 15g 9g
PoE support
