Getting Started with M5/M2Pro
Banana Pi BPI-M5
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
1. Download and install the AML Usb Burning Tool for android image download via USB type-c on M5 and Micro-usb on M2pro, only support windows.
3. M5 and M2pro are compatiable with same android image.
2. M5/M2pro board disconnect power, press and hold SW4 button beside 40pin header, plugin type-c usb cable(microUSB on m2pro) to PC
4. After Burning successfull, Unplug the usb and connect to power supply adaptor to startup.
or you can get the source code tar archive from BaiduPan or GoogleDrive.
BaiduPan:
GoogleDrive:
Android DTB overlay
Bananapi M5/M2Pro DTBO idx value table, default idx value is 0 in release image.
Bananapi M5/M2pro DTBO idx value table
2 i2c2 enable i2c 2
3 i2c3 enable i2c 3
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m5:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
IR Remote Control Custom
  • Android keycode.
push remote.cfg back
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 max_frame_time = 1000
3. Get the remote keycode
custom_code = 0xfe01
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 custom_name = nec-test
 fn_key_scancode = 0xffff
 cursor_left_scancode = 0xffff
 cursor_up_scancode = 0xffff
 cursor_down_scancode = 0xffff
 cursor_ok_scancode = 0xffff
 release_delay = 80
 map_size = 13
 key[0] = 0x74
 key[1] = 0x1008b
 key[2] = 0x90066
 key[3] = 0x20069
 key[4] = 0xa006a
 key[5] = 0x50067
 key[6] = 0x4006c
 key[7] = 0x6001c
 key[8] = 0x30072
 key[9] = 0xb0073
 key[10] = 0x40009e
 key[11] = 0x4800a4
 key[12] = 0x440071
5. Reboot the board
2. M5 and M2pro are compatiable with same Linux image.
4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
 $ apt-get install pv
Install Image to SDcard
3. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
Install Image to EMMC
3. There are two ways to install the linux image to board.
 3.1 Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 3.2 Install the linux image in udisk with bpi-tools command
4. After download complete, power off safely and eject the SDcard.
Build Linux Source Code
2. Build the bsp source code
2. Update the overlays env in vfat /boot/firmware/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
 # Overlays to load
 # Example combinations:
 #   spi0 i2c0 i2c1 uart0
 #   hktft32
 #   hktft35
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
Build and install
 $ sudo apt-get install build-essential python python-dev python-setuptools git
 $ cd RPi.GPIO-Amlogic
WiringPi2-Python
Build and install
 $ sudo apt-get install python python-dev python-setuptools swig git
 $ cd WiringPi2-Python-Amlogic
Boot Linux from USB drive
S905x3 is not support usb boot in soc rom, so the only way for booting linux from usb drive is create a bootable sdcard or emmc with bootloader flashed, then load boot and rootfs from usb drive. After bootup, everything will run from usb drive.
1. The simple way is flash the M5/M2Pro Linux image to sdcard or emmc for bootable and also flash it to the usb drive for loading boot and rootfs.
2. Bootup the M5/M2pro board with sdcard or emmc, copy /boot/boot.ini to /boot/boot.ini.org so that bootloader load boot.ini fail and then try to load it from usb drive boot partition.
3. Reboot the system, bootscript and rootfs will load from usb drive.
4. Test performance
You can verify the performance of your usb drive on Pi Benchmarks using the following command:
Test results for sd, emmc and usb drive
Category Test Sdcard Test Result Emmc Test Result Usb Drive Test Result
HDParm Disk Read 67.91 MB/s 156.64 MB/s 253.40 MB/s
HDParm Cached Disk Read 57.39 MB/s 126.53 MB/s 253.52 MB/s
DD Disk Write 13.0 MB/s 48.8 MB/s 149 MB/s
FIO 4k random read 2456 IOPS (9826 KB/s) 9701 IOPS (38806 KB/s) 5474 IOPS (21897 KB/s)
FIO 4k random write 938 IOPS (3753 KB/s) 12888 IOPS (51554 KB/s) 6980 IOPS (27920 KB/s)
IOZone 4k read 10615 KB/s 29568 KB/s 23770 KB/s
IOZone 4k write 4276 KB/s 33585 KB/s 18598 KB/s
IOZone 4k random read 8661 KB/s 29637 KB/s 19982 KB/s
IOZone 4k random write 4795 KB/s 38177 KB/s 22134 KB/s
Score: 1300 Score: 7811 Score: 5879
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
a). Using usb burning tool, unplug the download usb cable while the download process at 7% formatting
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   bananapi_m5_v1#amlmmc erase 1
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m5_v1#reset
   resetting ...
   BPI: try boot from sdcard
   reading boot.ini
   reading Image.gz
   reading uInitrd
   reading overlays/i2c0.dtbo
   reading overlays/spi0.dtbo
   reading overlays/uart1.dtbo
   bananapi_m5# mmc erase 0 1000
 $ sync
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt(usb)
 rtl8188eu wifi(usb)
 rtl8821cu wifi/bt(usb)
 rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
2. Linux test and support.
 rtl8188eu wifi(usb)
 rtl8192eu wifi(usb)
 rtl8811au wifi(usb)
 rtl8812au wifi(usb)
 rtl8812bu wifi(usb)
How to enable Linux Wifi
SDIO/UART type:
2). Configure the dtb overlay
  # Overlays to load
  #   hktft32
  #   hktft35
 88x2cs
How to enable Linux Bluetooth
Netplan
Linux Wifi STA mode
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      dhcp4: true
      access-points:
        "bananapi":
           password: "123456789"
Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 2.4GHz
         channel: 6
         auth:
           key-management: psk
network:
version: 2
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 5GHz
         channel: 36
         auth:
           key-management: psk
network:
version: 2
renderer: networkd
ethernets:
  wlan0:
    dhcp4: no
    addresses:
      - 192.168.11.1/24
2). Install hostapd
$ sudo apt install hostapd
interface=wlan0
ssid=bananapi
driver=nl80211
auth_algs=1
wpa=2
wpa_passphrase=123456789
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
#bridge=br0
beacon_int=500
#SSID not hidden
ignore_broadcast_ssid=0
hw_mode=a
channel=36
max_num_sta=8
### IEEE 802.11n
ieee80211n=1
#require_vht=0
### IEEE 802.11ac
ieee80211ac=1
#require_vht=0
#vht_oper_chwidth=1
### WMM
wmm_enabled=1
INTERFACESv4="wlan0"
  option routers 192.168.11.1;
5). Start Service
6). Routing configuration.
sysctl net.ipv4.ip_forward=1
Cloud-init&Snap
or
 $ sudo apt purge cloud-init
2. disable or remove snap
 $ sudo apt purge snapd
Enable rc-local
 [Unit]
 After=network.target
 [Service]
 Type=forking
 ExecStart=/etc/rc.local start
 TimeoutSec=0
 RemainAfterExit=yes
 GuessMainPID=no
 [Install]
 WantedBy=multi-user.target
 Alias=rc-local.service
Create /etc/rc.local file.
 sudo nano /etc/rc.local
 #!/bin/sh
 # rc.local
 # value on error.
 # bits.
 exit 0
 $ sudo chmod +x /etc/rc.local
 $ sudo reboot
Enable sudo for Debian
 $ su -
 Password:(enter bananapi)
 # apt install sudo
 # adduser pi sudo
Install Docker Engine
1. Set up the repository
 $ sudo apt-get update
Set up the stable repository
 $  echo \
2. Install Docker Engine
 $ sudo docker run hello-world
