Banana Pi Series Comparison
| Banana Pi Single board computer Comparison | ||||||||||
| module | BPI-M1 | BPI-M1+ | BPI-M2+ | BPI-M2 Zero | BPI-M2 Magic | BPI-M2 Berry | BPI-M2 Ulra | BPI-M3 | BPI-M64 | |
| photo | ||||||||||
| CPU | A20,32 Bit Cortex™-A7 Dual-Core | A20,32 Bit Cortex™-A7 Dual-Core | H3,32 Bit Cortex™-A7 Quad-Core | H2+,32 Bit Cortex™-A7 Quad-Core | A33/R16,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | A83T,32 Bit Cortex™-A7 Octa-Core | A64, 64 Bit Cortex A53 Quad Core | |
| GPU | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | |||||
| Memory \(SDRAM\) | 512M \(shared with GPU\) | |||||||||
| Onboard Storage | TF card \(Max. 64GB\) | |||||||||
| Onboard Network | NOPE | |||||||||
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | |||||||||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | |||||||||
| Video Outputs | Supports Mini HDMI Port | |||||||||
| Audio Output | Mini HDMI | |||||||||
| Power Source | Micro USB with 5V/2A | |||||||||
| USB 2.0 Ports | one USB 2.0 OTG | |||||||||
| Buttons | Power Button, Reset Button | |||||||||
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | |||||||||
| uart GPIO\(1x3\) pin | UART, ground | |||||||||
| LED | Power led & Status led | |||||||||
| IR | nope | |||||||||
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | |||||||||
| Product size | 65mm × 30mm | |||||||||
| Weight | 35g | |||||||||
