Getting Started with CM4
[hide]- 1 Introduction
- 2 specifications
- 3 development
- 3.1 Prepare
- 3.2 Android
- 3.3 Linux
- 3.3.1 Prepare
- 3.3.2 Install Image to SDcard
- 3.3.3 Install Image to EMMC
- 3.3.4 Build Linux Source Code
- 3.3.5 DTB overlay
- 3.3.6 Enable Camera
- 3.3.7 Switch Mipi Panel
- 3.3.8 Panel Rotation
- 3.3.9 WiringPi
- 3.3.10 RPi.GPIO
- 3.3.11 WiringPi2-Python
- 3.3.12 Custom Linux Boot Logo
- 3.3.13 EC20 LTE 4G Module
- 3.3.14 Boot Linux from SSD
- 3.4 Other Development
Android DTB overlay
- Bananapi CM4 DTBO idx value table, default idx value is 0 in release image.
Bananapi CM4 DTBO idx value table idx value device tree overlay description 0 android_p_overlay default dtbo, no use 1 wifi_bt_rtl8822cs enable bpi rtl8822cs wifi/bt module 2 i2c1 enable i2c 1 3 i2c2 enable i2c 2 4 sdio enable sdio 5 uart1 enable 2 pins uart 1 6 uart1_cts_rts enable 4 pins uart 1 7 uart2 enable 2 pins uart 2 8 hifi_pcm5122 enable i2s pcm5122 HiFi DAC
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
diff --git a/device/bananapi/bananapi_m2s/bananapi_m2s.mk b/device/bananapi/bananapi_m2s/bananapi_m2s.mk index 1f51703..d592a44 100644 --- a/device/bananapi/bananapi_m2s/bananapi_m2s.mk +++ b/device/bananapi/bananapi_m2s/bananapi_m2s.mk @@ -579,6 +579,6 @@ PRODUCT_PROPERTY_OVERRIDES += \ else PRODUCT_PROPERTY_OVERRIDES += \ ro.sf.lcd_density=213 \ - ro.sf.primary_display_orientation=0 + ro.sf.primary_display_orientation=90 endif
diff --git a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts index 4a698b0..3d41b63 100755 --- a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts +++ b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts @@ -876,8 +876,8 @@ reg = <0x5d>; reset-gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; irq-gpio = <&gpio GPIOA_5 GPIO_ACTIVE_HIGH>; - rotation = <4>; /* sf_rotation 0 */ - //rotation = <0>; /* sf_rotation 90*/ + //rotation = <4>; /* sf_rotation 0 */ + rotation = <0>; /* sf_rotation 90*/ //rotation = <5>; /* sf_rotation 180 */ //rotation = <3>; /* sf_rotation 270 */
Custom Android Boot Logo
- 4. Extract this tool
- 4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 3. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/sdX
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/mmcblk0
root@bananapi:~# ls /boot/overlays/ hifi_pcm5122.dtbo pdmmic.dtbo sdio.dtbo waveshare_tft24_lcd.dtbo i2c1.dtbo pwm_c-beeper.dtbo spi0.dtbo waveshare_tft35c_lcd.dtbo i2c2.dtbo pwm_cd-c.dtbo spi0_flash.dtbo wifi_bt_rtl8822cs.dtbo i2s.dtbo pwm_cd.dtbo uart1_cts_rts.dtbo i2smic.dtbo pwm_ef.dtbo uart1.dtbo os08a10.dtbo pwm_ef-f.dtbo uart2.dtbo
Enable Camera
overlays="os08a10"
Switch Mipi Panel
Panel Rotation
Section "Device" Identifier "Configured Video Device" # Rotate off # Option "Rotate" "off" # Rotate Right / clockwise, 90 degrees Option "Rotate" "CW" # Rotate upside down, 180 degrees # Option "Rotate" "UD" # Rotate counter clockwise, 270 degrees # Option "Rotate" "CCW" EndSection Section "InputClass" Identifier "Coordinate Transformation Matrix" MatchIsTouchscreen "on" MatchProduct "goodix-ts" MatchDevicePath "/dev/input/event0" MatchDriver "libinput" # Rotate Right / clockwise, 90 degrees Option "CalibrationMatrix" "0 1 0 -1 0 1 0 0 1" # Rotate upside down, 180 degrees # Option "CalibrationMatrix" "-1 0 1 0 -1 1 0 0 1" # otate counter clockwise, 270 degrees # Option "CalibrationMatrix" "0 -1 1 1 0 0 0 0 1" EndSection
- Note: This WiringPi only support set 26pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, ..., you must enable dtb overlay in boot.ini
- lcd1602-pi, BPI LCD 1602 display module example.
- Build and install
WiringPi2-Python
- Build and install
$ sudo apt-get Install python python-dev python-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python setup.py install
EC20 LTE 4G Module
- 1. AT test
- After the module is connected and Linux OS bootup. several ttyUSB* device files are created in the directory /dev. For EC20, /dev/ttyUSB2 is the AT port.
- 2. Connect Network via qmi_wwan on Ubuntu Desktop
- Choose qmi channel device
- When the qmi_wwan_q driver has been installed in the module, a network device and a QMI channel are created. The network device is named as wwanX and the QMI channel is /dev/cdc-wdmX. The network device is used for data transmission, and QMI channel is used for QMI message interaction
- Choose carrier provider.
- Set connection name, carrier connection username/password and APN if needed.
- 3. Connect Network via pppd on Ubuntu&Debian Server
- Install pppd
$ sudo apt install ipppd
- Two ways command to start pppd, you can check the process of PPP calling setup log here.
# pppd call quectel-ppp &
- or
- Terminate pppd process:
# quectel-ppp-kill
- 4. Connect Network via qmi_wwan on Ubuntu&Debian Server
- [quectel-CM] is a connection manager program for you to set up data connection manually. You can check the process of qmi_wwan calling setup log here.
# quectel-CM &
- Terminate quectel-CM process:
# killall quectel-CM
Boot Linux from SSD
- The legacy BPI-M2S-bsp is not support nvme in cpu rom and uboot, so the only way for booting linux from SSD is create a bootable sdcard or emmc with bootloader and boot partition flashed, then load rootfs from SSD. After bootup, everything will run from SSD. You need a minipcie to nvme adapter board because bananapi cm4io has a minipcie slot onboard.
- 1. The simple way is flash the CM4 Linux image to sdcard or emmc for bootable and alse flash it to the nvme ssd for loading rootfs.
- 2. Bootup the CM4 board with sdcard or emmc, modify /boot/boot.ini to load rootfs from nvme partition for kernel.
diff a/boot.ini b/boot.ini index 2222e79..c485067 100755 --- a/boot.ini +++ b/boot.ini @@ -20,6 +20,8 @@ fi; if test "${devtype}" = "usb"; then setenv rootfsdev "/dev/sda2"; fi +# force set root=/dev/nvme0n1p2 +setenv rootfsdev "/dev/nvme0n1p2" + # Load env.txt fatload ${devtype} ${devno}:1 ${env_loadaddr} env.txt env import -t ${env_loadaddr} ${filesize};
- 3. Reboot the system, kernel will load rootfs from nvme ssd.
- 4. Test performance
- You can verify the performance of your SSD on Pi Benchmarks using the following command:
- Test results for sd, emmc and nvme ssd
Category Test Sdcard Test Result Emmc Test Result Nvme SSD Test Result HDParm Disk Read 60.67 MB/s 148.80 MB/s 351.29 MB/s HDParm Cached Disk Read 56.71 MB/s 141.02 MB/s 347.03 MB/s DD Disk Write 14 MB/s 51.0 MB/s 244 MB/s FIO 4k random read 2176 IOPS (8704 KB/s) 8438 IOPS (33753 KB/s) 101386 IOPS (405544 KB/s) FIO 4k random write 932 IOPS (3729 KB/s) 10876 IOPS (43505 KB/s) 43206 IOPS (172827 KB/s) IOZone 4k read 8586 KB/s 20311 KB/s 119475 KB/s IOZone 4k write 2385 KB/s 19016 KB/s 90619 KB/s IOZone 4k random read 6734 KB/s 20807 KB/s 51517 KB/s IOZone 4k random write 3737 KB/s 22731 KB/s 95139 KB/s Score: 1076 Score: 5446 Score: 24550
Boot Sequence
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
$ su - Password:(enter bananapi) # apt install sudo # adduser pi sudo
Install Docker Engine
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
