BPI-Bit-S2
[hide]About BPI-Bit-S2
BPI-Bit-S2 development board is a successor to BPI:Bit, inheriting most of the core hardware functions.
Key features
- ESP32-S2
- 5x5 RGB LED matrix
- 1 buzzer
- 1 thermistor sensor
- 2 photosensitive sensors
- 2 programmable keys,1 BOOT key,1 Reset key
- Type-C USB interface
- Size 5x5cm
- The Goldfinger Edge Connector definition is fully compatible with Micro: Bit
Hardware upgrade and function comparison
BPI:Bit VS BPI-Bit-S2 | ||
Module | BPI:Bit | BPI-Bit-S2 |
MCU | ESP32 | ESP32-S2 |
ROM | 448 KB | 128 KB |
RAM | 520 KB | 320 KB |
FlASH ROM | 4096 KB | 4096 KB |
PSRAM | None | 2048 KB |
Wireless Capability | WIFI,Bluetooth | WIFI |
LED | 25 WS2812-5050 RGB LED | 25 WS2812-3535 RGB LED |
Key | 2 programmable keys,1 RST key | 2 programmable keys,1 BOOT key,1 RST key |
Buzzer | 5.3x5.3mm buzzer | 8.5x8.5mm buzzer |
USB interface | Micro USB | Type-C USB |
USB to TTL | support | None |
Battery socket | support | None |
IO | 19 pin Goldfinger IO | 19 pin Goldfinger IO |
Nine-axis sensor | support | None |
Photosensitive sensor | 2 | 2 |
Thermistor sensor | 1 | 1 |
BPI-Bit-S2 specification | |
MCU | ESP32-S2FN4R2,Xtensa® 32 bit LX7 Single-Core Processer |
Frequency | 240MHz MAX |
operating temperature | -40℃~+85℃ |
ROM | 128 KB |
SRAM | 320 KB |
FLASH ROM | 4 MB |
PSRAM | 2 MB |
WIFI | IEEE 802.11 b/g/n ,2.4Ghz |
GPIO | 19 available GPIO pins have been introduced |
Peripheral functions | ADC,TOUCH,PWM,SPI,I2C,I2S,Pulse counter, RMT,TWAI® Controller,SD/MMC,LCD_CAMERA |
External crystal | 40Mhz |
Buzzer | 8.5x8.5mm buzzer |
LED | 25 WS2812 rgb LED, single line GPIO control; 1 monochrome LED, controlled by GPIO0 |
Photosensitive sensor | 2 photosensitive sensor |
Thermistor sensor | 1 thermistor sensor |
IO | 19 pins Goldfinger IO,19 pins contacts on the back |
Key | 2 programmable keys,1 BOOT key,1 Reset key |
USB | USB Type-C interface,full speed USB OTG,USB-ACM |
Operating voltage | 3.3V |
Power | USB Type-C input 5V,or Goldfinger IO input 3.3V power supply |
Size | 5 * 5 cm |
On-board peripherals
Peripheral GPIO allocation and signal type | ||
Photosensitive sensor(L) | GPIO 12 | Analog Input |
Photosensitive sensor(R) | GPIO 13 | Analog Input |
Thermistor sensor | GPIO 14 | Analog Input |
Key A | GPIO 38 | Digital Input |
Key B | GPIO 33 | Digital Input |
Key BOOT | GPIO 0 | Digital Input |
Buzzer | GPIO 17 | PWM(Digital Output) |
RGB LEDs | GPIO 18 | Digital Output |
5*5 RGB LED
BPI-Bit-S2 have 25 WS2812 full color RGB LED, single GPIO ontrol.The three primary color pixels of each LED can achieve 8bit 256 level brightness display, and achieve 16777216 color full color display, scanning frequency is not less than 400Hz/s.
5*5 LEDs list of BPI-Bit-S2 | ||||
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
Goldfinger GPIO define
SPI,I2C | ||
Function | Pin Name | GPIO Num |
SPI_SCK | P13 | GPIO36 |
SPI_MISO | P14 | GPIO37 |
SPI_MOSI | P15 | GPIO35 |
SPI_CS | P16 | GPIO34 |
I2C_SCL | P19 | GPIO16 |
I2C_SDA | P20 | GPIO15 |
Power
Webduino
Arduino
Preparing...
MicroPython
Preparing...
