Getting Started with CM4
[hide]Introduction
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
diff --git a/device/bananapi/bananapi_m2s/bananapi_m2s.mk b/device/bananapi/bananapi_m2s/bananapi_m2s.mk index 1f51703..d592a44 100644 --- a/device/bananapi/bananapi_m2s/bananapi_m2s.mk +++ b/device/bananapi/bananapi_m2s/bananapi_m2s.mk @@ -579,6 +579,6 @@ PRODUCT_PROPERTY_OVERRIDES += \ else PRODUCT_PROPERTY_OVERRIDES += \ ro.sf.lcd_density=213 \ - ro.sf.primary_display_orientation=0 + ro.sf.primary_display_orientation=90 endif
diff --git a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts index 4a698b0..3d41b63 100755 --- a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts +++ b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts @@ -876,8 +876,8 @@ reg = <0x5d>; reset-gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; irq-gpio = <&gpio GPIOA_5 GPIO_ACTIVE_HIGH>; - rotation = <4>; /* sf_rotation 0 */ - //rotation = <0>; /* sf_rotation 90*/ + //rotation = <4>; /* sf_rotation 0 */ + rotation = <0>; /* sf_rotation 90*/ //rotation = <5>; /* sf_rotation 180 */ //rotation = <3>; /* sf_rotation 270 */
Custom Android Boot Logo
- 4. Extract this tool
- 4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
Install Image to SDcard
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 3. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/sdX
Install Image to EMMC
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/mmcblk0
Build Linux Source Code
root@bananapi:~# ls /boot/overlays/ hifi_pcm5122.dtbo pdmmic.dtbo sdio.dtbo waveshare_tft24_lcd.dtbo i2c1.dtbo pwm_c-beeper.dtbo spi0.dtbo waveshare_tft35c_lcd.dtbo i2c2.dtbo pwm_cd-c.dtbo spi0_flash.dtbo wifi_bt_rtl8822cs.dtbo i2s.dtbo pwm_cd.dtbo uart1_cts_rts.dtbo i2smic.dtbo pwm_ef.dtbo uart1.dtbo os08a10.dtbo pwm_ef-f.dtbo uart2.dtbo
Enable Camera
overlays="os08a10"
Switch Mipi Panel
Panel Rotation
Section "Device" Identifier "Configured Video Device" # Rotate off # Option "Rotate" "off" # Rotate Right / clockwise, 90 degrees Option "Rotate" "CW" # Rotate upside down, 180 degrees # Option "Rotate" "UD" # Rotate counter clockwise, 270 degrees # Option "Rotate" "CCW" EndSection Section "InputClass" Identifier "Coordinate Transformation Matrix" MatchIsTouchscreen "on" MatchProduct "goodix-ts" MatchDevicePath "/dev/input/event0" MatchDriver "libinput" # Rotate Right / clockwise, 90 degrees Option "CalibrationMatrix" "0 1 0 -1 0 1 0 0 1" # Rotate upside down, 180 degrees # Option "CalibrationMatrix" "-1 0 1 0 -1 1 0 0 1" # otate counter clockwise, 270 degrees # Option "CalibrationMatrix" "0 -1 1 1 0 0 0 0 1" EndSection
- lcd1602-pi, BPI LCD 1602 display module example.
- Build and install
WiringPi2-Python
- Build and install
$ sudo apt-get Install python python-dev python-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python setup.py install
Custom Linux Boot Logo
EC20 LTE 4G Module
Boot Sequence
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
$ su - Password:(enter bananapi) # apt install sudo # adduser pi sudo
Install Docker Engine
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
