BPI-Pico-RP2040
Revision as of 02:06, 25 November 2022 by Wind (talk | contribs) (Created page with "zh:BPI-Pico-RP2040_开发板 = Introduction = 750px thumb|[[BPI-PicoW-S3 with ESP32-S3]] File:PICO-1000-5....")
BPI-Leaf-S3 with ESP32-S3
BPI-Bit with ESP32
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
The Banana Pi Pico series is a low-power microcontroller development board designed for the Internet of Things.
BPI-Pico-RP2040 is a microcontroller development board launched by Banana Pi equipped with RP2040 chip. Its most notable feature is to add a Onboard WS2812 color LED; replace the 3-Pin DEBUG interface with a JST SH 1mm 4-Pin socket, which can be connected with Qwiic & STEMMA QT or any possible peripherals; replace the micro-USB socket with a USB Type-C socket , supports reversible insertion, and is compatible with the USB Type-C cable of most modern smartphones, no additional purchase is required.
key features
  • Dual-core ARM Cortex M0+ CPU cores (up to 133 MHz)
  • 264K SRAM
  • 2MB Flash
  • 26 available GPIO pins, 4 of which support ADC analog input
  • 1 x LED
  • 1 x WS2812 LED
  • 1 × JST SH 1mm 4-Pin socket
  • 1 × USB Type-C socket
Hardware Size
BPI-PicoW-S3 size chart
Pin spacing 2.54mm
Mounting hole spacing 17.6mm/ 11.4mm
Mounting hole size Inner diameter 2.1mm/outer diameter 3.4mm
Mainboard size 11.4 × 55.8(mm)
Thickness 1.2mm
The pin spacing is compatible with universal boards (hole boards, dot matrix boards) and breadboards, which is convenient for debugging applications.
