Getting Started with P2-Zero
Revision as of 02:11, 22 September 2022 by Czj (talk | contribs) (Basic Development)
Overview: BPI-M2Z raspbian
BPI-P2 Zero
Banana Pi BPI-P2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: Allwinner H2+, Quad-core Cortex-A7
  • 512MB DDR 3 SDRAM
  • Mini HDMI
  • 40 PIN GPIO, It includes UART, SPI, I2C, IO etc
  • 100M LAN
  • 8G eMMC flash onboard
Development For Android
Load your first image on M1
 * Using your USB-Serial Connect debug console on P2 Zero
Install Linux Image on P2 Zero
Install Image to SDcard on Linux PC with bpi-tools
1. Install bpi-tools on your system
   $ apt-get install pv
If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
2. Insert your SDcard into your PC
   $ bpi-copy xxx.img /dev/sdx
1.Prepare a sd which is installed ubuntu image and bootup with sdcard
2.Copy emmc image to udisk, plug in board, then mount udisk.
3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
1. Get the p2 zero bsp source code
   $ git clone https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4
2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
How to create an image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
EMac
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
