BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
File and burn position corresponding | |||
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | SPI SPEED | 40NHz | |
2 | SPI MODE | DIO | |
3 | FLASH SIZE | 32Mbit | |
4 | COM | COMx(Fill in the port number assigned by the computer) | |
5 | BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
