BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
- File and burn position corresponding to::
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SPI SPEED40NHz
SPI MODEDIO
FLASH SIZE32Mbit
COMCOMx(Fill in the port number assigned by the computer)
BAUD1152000
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
