Getting Started with BPI-R3
Revision as of 04:45, 15 August 2022 by Sinovoip (talk | contribs) (Ap mode on R64)
  • . Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
  • . 2G DDR RAM
  • . 8G eMMC flash
  • . 2 SFP 2.5GbE
  • . 5 GbE network port
  • . POE support (optional)
  • . Mini PCIe via USB
  • . M.2 KEY-E PCIe inerface
  • . Mciro SD card interfact
  • . 26 PIN GPIO
 * Using your USB-Serial Connect debug console on BPI-R3
How to burn image to SD card
   * apt-get install pv
   4.After step 3, then you can insert your TF card into R3, and press power button to setup R3
   1. Download the tools from the website:   https://sourceforge.net/projects/win32diskimager/
   3. flash image into SD card.
 Note: because SD card and EMMC device share one SOC's interface, you need flash one SD image firstly, then R3 boot from SD card, then flash nand image into Nand, then change boot strap to boot from nand,  you need flash EMMC image into EMMC. Finally you change bootstrap to boot from EMMC.
    * mtd erase /dev/mtd0
    * dd if=mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bi of=/dev/mtdblock0
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
lo Link encap:Local Loopback
         Interrupt:6
root@OpenWrt:/#
GPIO
26 Pins Definition
  • echo 431(22+409) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio431/direction
  • echo 1 > /sys/class/gpio/gpio431/value
PWM Control
PCIe
  • If you want to use PCIe interface on R64, you need to give GPIO90 high level
    • echo 499 > /sys/class/gpio/export
    • echo out > /sys/class/gpio/gpio499/direction
    • echo 1 > /sys/class/gpio/gpio499/value
  • PCIe supports EC-25 4G module.
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On R64 console:
R64 LAN Function
  • LAN eth interface is eth2, use "ifconfig eth2 up" to enable it.
  • Config the ip, "ifconfig eth2 192.168.1.1".
  • Config your dhcp server, "vim /etc/dhcp/dhcpd.conf", add these configurations.
  • Start dhcp server, "dhcpd eth2".
  • then config iptables and set package forward.
    • Add "net.ipv4.ip_forward=1" to "/etc/sysctl.conf"
    • "/sbin/sysctl -p" to make forward work
    • "iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth3 -j MASQUERADE"
Ap mode on BPI-R3
  • ra0 is MT7986a 2.4G wifi
  • rax0 is MT7986a 5G wifi
  • MT7986a Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
Reference Link
http://forum.banana-pi.org/
