Getting Started with BPI-R3
Revision as of 19:43, 10 August 2022 by Sinovoip (talk | contribs) (40 Pins Definition)
  • . Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
  • . 2G DDR RAM
  • . 8G eMMC flash
  • . 2 SFP 2.5GbE
  • . 5 GbE network port
  • . POE support (optional)
  • . Mini PCIe via USB
  • . M.2 KEY-E PCIe inerface
  • . Mciro SD card interfact
  • . 26 PIN GPIO
 * Using your USB-Serial Connect debug console on BPI-R3
How to burn image to SD card
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
 Before burning image to eMMC, please prepare a SD card with flashed bootable image and a USB disk. Let's take OpenWrt image (mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) for example, the steps are below:
 1. Insert the flashed SD card and power on to start the board.(the image on the SD card can be OpenWrt or other linux OS like ubuntu...)
 2. Copy eMMC bootable OpenWrt image(mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
 4. Execute following command to enable and copy image to eMMC:
    * dd if=2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img of=/dev/mmcblk0
    * dd if=mtk-bpi-r64-preloader-emmc.bin of=/dev/mmcblk0boot0
    * mmc bootpart enable 1 1   /dev/mmcblk0
 5. Shutdown, remove SD card and USB disk, and restart the board from eMMC.
Network-Configuration
GPIO
40 Pins Definition
  • echo 431(22+409) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio431/direction
  • echo 1 > /sys/class/gpio/gpio431/value
PWM Control
SPI touch panel
SPI Panel module:
SPI Panel <–> BPIR64
T_DO, T_DIN, T_CLK <–> SPIC_0: MOSI / MISO / CLK
T_CS <–> SPI-CE0
T_IRQ <–> IO-37
SDO, SCK, SDI <–> SPIC_1: MOSI / MISO / CLK
LED <–> PIN-31
DC <–> PIN-11
RESET <–> PIN-13
CS <–> SPI-CE1
GND <–> GND-9
VCC <–> 3.3V-1
DTS Modification:
       backlight: backlight {
               compatible = "gpio-backlight";
               gpios = <&pio 82 GPIO_ACTIVE_HIGH>;        //PIN31 IO-31 : GPIO82
               default-on;
&pio {
       spic0_pins: spic0-pins {
               mux {
                       function = "spi";
                       groups = "spic0_0";
       spic1_pins: spic1-pins {
               mux {
                       function = "spi";
                       groups = "spic1_0";
&spi0 {
       pinctrl-names = "default";
       pinctrl-0 = <&spic0_pins>;
       status = "okay";
       touch@0 {
               reg = <0>;                                 //CE0
               compatible = "ti,ads7843";
               interrupt-parent = <&pio>;
               interrupts = <86 0>;                       //PIN37: IO-37 == GPIO86
               pendown-gpio = <&pio 86 0>;
               spi-max-frequency = <1000000>;
               vcc-supply = <&reg_3p3v>;
               wakeup-source;
&spi1 {
       pinctrl-0 = <&spic1_pins>;
       status = "okay";
       display@0{
               compatible = "ilitek,ili9341";
               reg = <0>;                                 //CE0
               spi-max-frequency = <32000000>;
               dc-gpios = <&pio 51 GPIO_ACTIVE_HIGH>;     //PIN11 UART1-TXD : GPIO51
               reset-gpios = <&pio 52 GPIO_ACTIVE_HIGH>;  //PIN13 UART1-RXD : GPIO52
               backlight = <&backlight>;
Kernel config:
+CONFIG_FB_TFT_ILI9341
+CONFIG_FB_TFT
+CONFIG_FB
+CONFIG_BACKLIGHT_LCD_SUPPORT
+CONFIG_BACKLIGHT_CLASS_DEVICE
+CONFIG_BACKLIGHT_GPIO
+CONFIG_INPUT
+CONFIG_INPUT_TOUCHSCREEN
+CONFIG_TOUCHSCREEN_ADS7846
Application:
Package + Description Source
fbv framebuffer image viewer https://github.com/godspeed1989/fbv
input-event-daemon input-event-daemon with touchTEST event https://github.com/SAM33/input-event-daemon
[Global]
listen = /dev/input/event0
listen = /dev/input/event1
[TouchTEST]
340,400,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/bpi_608x429.jpg -s 1
340,2260,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/openwrt_449x449.png -s 1
Banana Pi BPI-R64 SPI touch panel test: https://www.youtube.com/watch?v=ikag-D_TI0g&feature=youtu.be
Sata
  • If you want to use Sata interface on R64, you need to give GPIO90 low level
    • echo 499 > /sys/class/gpio/export
    • echo out > /sys/class/gpio/gpio499/direction
    • echo 0 > /sys/class/gpio/gpio499/value
  • Test a TOSHIBA HDD DISK, the Read/Write performance are below:
Read from disk: 50MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 38MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
Read from disk: 360MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 200MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
PCIe
  • If you want to use PCIe interface on R64, you need to give GPIO90 high level
    • echo 1 > /sys/class/gpio/gpio499/value
  • PCIe supports EC-25 4G module.
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On R64 console:
BT & BLE on R64
R64 BT Architectural
  • BLE on R64
  • Input Command "btmw-test", you will enter to "btmw_test_cli" command line
  • Here are some example commands:
    • MW_GAP name 7622_BT /*rename bt device*/
    • MW_GAP info /*check local BT device info*/
    • MW_GATTC scan /* start ble scan*/
    • MW_GATTC stop_scan /* stop ble scan*/
R64 LAN Function
  • LAN eth interface is eth2, use "ifconfig eth2 up" to enable it.
  • Config the ip, "ifconfig eth2 192.168.1.1".
  • Config your dhcp server, "vim /etc/dhcp/dhcpd.conf", add these configurations.
  • Start dhcp server, "dhcpd eth2".
  • then config iptables and set package forward.
    • Add "net.ipv4.ip_forward=1" to "/etc/sysctl.conf"
    • "/sbin/sysctl -p" to make forward work
    • "iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth3 -j MASQUERADE"
Ap mode on R64
  • Find "mt_wifi.ko" and insmod it.
    • insmod ./lib/modules/4.4.92-BPI-R64-Kernel/extra/mt_wifi.ko
  • Then you will see ra0 and rai0.
  • ra0 is MT7622 2.4G wifi
  • rai0 is MT7615 5G wifi
2.4G WiFi
  • Use "ifconfig ra0 up" to enable it.
  • Config the ip, "ifconfig ra0 192.168.1.1".
  • Start dhcp server, "dhcpd ra0".
5G WiFi
  • Use "ifconfig rai0 up" to enable it.
  • Config the ip, "ifconfig rai0 192.168.1.1".
  • Start dhcp server, "dhcpd rai0".
  • MT7986a Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
Reference Link
http://forum.banana-pi.org/
