Banana Pi BPI-M2 Pro
BPI-M2 Pro Introduction
- Mali-G31 GPU
- 2GB LPDDR4
- 16GB eMMC flash
- 2 USB 3.0
- 1 GbE ethernet
- HDMI output
Hardware inerface
| HardWare Specification of Banana pi BPI-M2 Pro | |||
| Memory | 2 GB LPDDR4 | ||
| Network | 10/100/1000 Mbit/s Ethernet | ||
| Wifi&BT | Dual-band 802.11 b/g/n/ac WiFi 5 1×1 and Bluetooth 4.2 via Realtek RTL8821CU | ||
| Audio Output(s) | 1 x HDMI digital output | ||
| USB ports | 2x USB 3.0 host ports, 1x micro USB OTG port | ||
| Power Source | 5 volt @3A via DC port | ||
| Size & Weight | 65mm×65mm, 58g | ||
| OS | Android and Linux | ||
| Network | 1 GbE ,WiFi&BT4.2 onboard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
BPI-M2 Pro 40PIN GPIO (CON2)
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | VCC5V | ||
| CON1-P04 | VCC5V | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P39 | GND | ||
BPI-M2 Pro Debug UART(CON1)
| CON2-P1 | GND |
| CON2-P2 | UART0-RX |
| CON2-P3 | UART0-TX |
- same to BPI-M5 source code.
- BPI-M2 Pro PCB DXF file
- Amlogic S905x3 datasheet
- same to BPI-M5 images.
Rasbian
Third part image
CoreELEC
- CoreELEC 19.2
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
HuaWei OpenEuler
- Download:
Manjaro for BPI-M5
CoreELEC on BPI-M2 Pro
easy to buy sample : https://pt.aliexpress.com/item/1005002661831086.html?spm=a2g0o.store_pc_allProduct.8148356.1.4fd039a06wVleh
