Banana Pi BPI-R3
Application direction
  • . Internet service Router
  • . Wireless Router
  • . Wireless Repeater
  • . Home security Gateyway
  • . Home Automation
  • . Nas device
  • . Network and communication applications
  • . Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
  • . 2G DDR RAM
  • . 8G eMMC flash
  • . 2 SFP 2.5GbE
  • . 5 GbE network port
  • . Mini PCIe via USB
  • . M.2 KEY-E PCIe inerface
  • . Mciro SD card interfact
  • . 26 PIN GPIO
File:BPI-R3 interface 1.jpg
Jumper setting
Jumper Setting of Banana pi BPI-R3
CPU MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design
HardWare Specification of Banana pi BPI-R3
SDRAM 2 GB LPDDR3
GPIO 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
On board Network 5 Port 10/100/1000Mbps Ethernet
SFP 2 SFP 2.5GbE
Wifi Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
mini PCIE Mini PCIe via USB
M.2 interface M.2 KEY-E PCIe inerface
USB 1 USB 3.0 host ,2 USB interface with slot.
Buttons Reset button,WPS botton, boot switch
DC Power 12V/2A with DC in
Sizes 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2
Weight 200g
Release image
  • 2022-06-01udptae BPI-R3 OpenWRT 21.02 linux kerne 5.4, wifi 6E 2.4G and 5G working fine.support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware
Google drive :https://drive.google.com/file/d/18_xst-diDdCg7CeSum1M5FDbbo31jFJq/view?usp=drivesdk
baidu link https://pan.baidu.com/s/1idqU1-bB4XD1LTGDAJxRGA?pwd=chez Pincode: chez
Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-r3-openwrt-image/13236
