Getting Started with M5/M2Pro
Revision as of 19:45, 13 June 2022 by Dangku (talk | contribs) (Install Image to EMMC)
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
1. Download and install the AML Usb Burning Tool for android image download via USB type-c on M5 and Micro-usb on M2pro, only support windows.
3. M5 and M2pro are compatiable with same android image.
2. M5/M2pro board disconnect power, press and hold SW4 button beside 40pin header, plugin type-c usb cable(microUSB on m2pro) to PC
4. After Burning successfull, Unplug the usb and connect to power supply adaptor to startup.
Android DTB overlay
Bananapi M5/M2Pro DTBO idx value table, default idx value is 0 in release image.
Bananapi M5/M2pro DTBO idx value table
2 i2c2 enable i2c 2
3 i2c3 enable i2c 3
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m5:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
IR Remote Control Custom
  • Android keycode.
push remote.cfg back
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 max_frame_time = 1000
3. Get the remote keycode
custom_code = 0xfe01
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 custom_name = nec-test
 fn_key_scancode = 0xffff
 cursor_left_scancode = 0xffff
 cursor_up_scancode = 0xffff
 cursor_down_scancode = 0xffff
 cursor_ok_scancode = 0xffff
 release_delay = 80
 map_size = 13
 key[0] = 0x74
 key[1] = 0x1008b
 key[2] = 0x90066
 key[3] = 0x20069
 key[4] = 0xa006a
 key[5] = 0x50067
 key[6] = 0x4006c
 key[7] = 0x6001c
 key[8] = 0x30072
 key[9] = 0xb0073
 key[10] = 0x40009e
 key[11] = 0x4800a4
 key[12] = 0x440071
5. Reboot the board
 $ apt-get install pv
Install Image to SDcard
 $ sudo apt-get install pv
4. Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
Setting up Banana Pi with Ubuntu 20.04 Server from a Windows PC
  • Download latest version of Balena Etcher
  • Download image file from: Banana Pi Open Source Project (banana-pi.dev) 2
2021-06-21-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img.zip
  • Unzip the image file to a folder on your Windows machine
  • Used Balena Etcher to flash the unzipped image file (*.img) to an SD card
  • Copy the zipped (*.zip) version of the same file to a USB thumb drive (I had to reformat the USB drive to NTFS file system to copy the file to the USB stick…not sure why)
  • Boot up the Bpi M5 with the SD card
  • Login for Ubuntu was ‘pi’ with password ‘bananapi”
  • Can STOP HERE IF YOU JUST WANT TO BOOT UBUNTU FROM SD CARD
  • CONTINUE IF YOU WANT TO CONFIGURE M5 TO BOOT UBUNTU FROM EMMC If you proceed, you will no longer be able to boot from the SD card until you reformat EMMC
  • At the terminal prompt $, ran these two commands:
  • Insert the USB thumb drive into Bpi M5 and mount in via terminal $ using these commands:
sudo fdisk -l
Used to see what the OS is naming your USB drive
Mine was /dev/sda1
sudo mkdir /media/usb
Used to make a directory (mount point) for mounting the USB drive. This directory may already exist.
cd /media/usb
sudo mount /dev/sda1 /media/usb
Used to mount the USB drive to the /media/usb folder
ls
Lists the contents of the USB drive.
Should see your *.zip version of the Ubuntu image file
sudo bpi-copy 2021-06-21-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img.zip /dev/mmcblk0
Copies, unzips, and installs the image file onto the EMMC
I got an error at this point related to “unzip” not being a valid command
I just ran the command: sudo apt-get install unzip
Re-ran the command: sudo bpi-copy… listed above
  • The boot order for the Bpi M5 is Start ROM:Boot EMMC and then Boot SD Card, so if you want to go back to booting from the SD Card after installing an OS on the EMMC, you will have to erase it first and start over.
To erase the EMMC for SD Card bootup:
  • Connect the M5 to your computer via USB debug console cable
  • Use the Amlogic USB Burning Tool to format the EMMC
Build Linux Source Code
2. Build the bsp source code
2. Update the overlays env in vfat /boot/firmware/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
 # Overlays to load
 # Example combinations:
 #   spi0 i2c0 i2c1 uart0
 #   hktft32
 #   hktft35
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
Build and install
 $ cd RPi.GPIO-Amlogic
WiringPi2-Python
Build and install
 $ sudo apt-get Install python python-dev python-setuptools swig wiringpi git
 $ git clone https://github.com/Dangku/WiringPi2-Python-Amlogic.git
 $ cd WiringPi2-Python-Amlogic
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
a). Using usb burning tool, unplug the download usb cable while the download process at 7% formatting
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   bananapi_m5_v1#amlmmc erase 1
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m5_v1#reset
   resetting ...
   BPI: try boot from sdcard
   reading boot.ini
   reading Image.gz
   reading uInitrd
   reading overlays/i2c0.dtbo
   reading overlays/spi0.dtbo
   reading overlays/uart1.dtbo
   bananapi_m5# mmc erase 0 1000
 $ sync
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt(usb)
 rtl8188eu wifi(usb)
 rtl8821cu wifi/bt(usb)
 rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
2. Linux test and support.
 rtl8188eu wifi(usb)
 rtl8192eu wifi(usb)
 rtl8811au wifi(usb)
 rtl8812au wifi(usb)
 rtl8812bu wifi(usb)
How to enable Linux Wifi
SDIO/UART type:
2). Configure the dtb overlay
  # Overlays to load
  #   hktft32
  #   hktft35
How to enable Linux Bluetooth
Netplan
Linux Wifi STA mode
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      dhcp4: true
      access-points:
        "bananapi":
           password: "123456789"
Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 2.4GHz
         channel: 6
         auth:
           key-management: psk
network:
version: 2
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 5GHz
         channel: 36
         auth:
           key-management: psk
network:
version: 2
renderer: networkd
ethernets:
  wlan0:
    dhcp4: no
    addresses:
      - 192.168.11.1/24
2). Install hostapd
$ sudo apt install hostapd
interface=wlan0
ssid=bananapi
driver=nl80211
auth_algs=1
wpa=2
wpa_passphrase=123456789
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
#bridge=br0
beacon_int=500
#SSID not hidden
ignore_broadcast_ssid=0
hw_mode=a
channel=36
max_num_sta=8
### IEEE 802.11n
ieee80211n=1
#require_vht=0
### IEEE 802.11ac
ieee80211ac=1
#require_vht=0
#vht_oper_chwidth=1
### WMM
wmm_enabled=1
INTERFACESv4="wlan0"
  option routers 192.168.11.1;
5). Start Service
6). Routing configuration.
sysctl net.ipv4.ip_forward=1
Cloud-init&Snap
or
 $ sudo apt purge cloud-init
2. disable or remove snap
 $ sudo apt purge snapd
Install Docker Engine
1. Set up the repository
 $ sudo apt-get update
Set up the stable repository
 $  echo \
2. Install Docker Engine
 $ sudo docker run hello-world
